RV.Net Open Roads Forum: Rt. 95 South around Washington Beltway Rt. 495
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Rt. 95 South around Washington Beltway Rt. 495
Paul127
Cranston, RI
Posted: 02/23/12 05:55am Link  |  Print  |  Notify Moderator
Traveling Rt. 95 S. around Washington which way on the belway is best?
I will also be returning on 95N. after vacation should I go the same way?
Paul127
PCronin68
MA
Posted: 02/23/12 08:30am Link  |  Print  |  Notify Moderator
Paul, I also live in RI and when I go south I go RT287 to RT78 then down RT81. There are multiple points to get back to RT95 near Richmond, VA or further south. All depends on where your going. This way you avoid NY and DC traffic and RT81 is nice
2014 Fleetwood Bounder 34b
dahkota
Fulltiming
Posted: 02/23/12 09:20am Link  |  Print  |  Notify Moderator
Follow 95S around the eastern side (Maryland). If you go on the western side (495) you run into all the 270 traffic. Also, the road in that part of northern Virginia is abysmal. Construction and lane changes mixed with pot holes and level changes. Probably the worst piece of road in the area from the 270 spur down to where it rejoins 95.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped, 2014: 22; 2015: 19; 2016: 15 so far
more than 950 days on the road
Coloring the Void
Devocamper
West Haven CT
Posted: 02/23/12 11:52am Link  |  Print  |  Notify Moderator
Best bet is the inland route around washington and baltimore ,no tunnel and no outer bridge. can not use tunnel anyway if you have propane on board. depending where your going and how far south your headed ,78 81 the inland route through pa and VA is by far the easiest drive.
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
spitfirepete
Great Outdoors RV resort
Posted: 02/27/12 08:57am Link  |  Print  |  Notify Moderator
You will probably be sorry if you travel 95 with all the tolls and traffic.
Best to use 287/78/83/15/29 back to 95 in Fredericksburg.
We will never do the beltway again after trying it twice.
Peter and Linda
2011 Tiffin Phaeton
2007 Saturn Vue toad
Bichon and Cocker (spoiled puppies)
JamesBr
Manassas, VA
Posted: 02/27/12 09:18am Link  |  Print  |  Notify Moderator
IF you take 95S through the Baltimore-Washington area I recommend that you stay to the eastern side of the city (follow 95S) as the Western side has a LOT of construction from the Legion Bridge all the way to the southern 95 spur of the beltway. It is not towing friendly at all as you constantly shift lanes. I would say that you have a limited window to avoid lots of traffic southbound. I would not try to get through the DC belway area after 6am or before 9am and you need to get as far south of DC as you can before 2:30-3pm when the VA 95S becomes a congested nightmare for many miles.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
Drbolasky
Fogelsville, PA
Posted: 02/28/12 08:24pm Link  |  Print  |  Notify Moderator
I would avoid the Baltimore/DC mess if you can (via I-78, I-81, etc.) but again it depends on your exact destination. We've been through this area twice now in the last three months. We've had good luck taking the Baltimore beltway passing west of the city and the DC beltway passing east of DC. In any case avoid rush hours at all costs.
On both of the recent trips the more severe bottleneck has been I-95 below DC. The stretch from around Lorton south to Fredericksburg is almost always congested, usually because the HOV lanes empty into the left (fast) lanes of I-95. Next thing you know you've got drivers cutting off other drivers and it just bogs down from there.
Doug, Linda, Audrey (USN) & Andrew
2008 Sequoia SR-5, 5.7 L, 2000 Coachmen Futura 2790TB Bunkhouse, Dexter E-Z Flex Suspension, Reese W.D. Hitch/Dual Cam Sway Control, Prodigy Brake Controller, McKesh Mirrors
LarryJM
NoVa
Posted: 02/29/12 01:03am Link  |  Print  |  Notify Moderator
You're getting some good advice on "Just Say No" to I-95/495 anywhere around or near D.C. My recommendation is to take I-81 and pick up US-15 at Harrisburg down to US-29 in Gainsville then south on 29 towards Warrenton and pick up US-17 in Opal, Va and follow that down to I-95 at Fredericksburg. You won't win any races on US-15 or 17, but the drive is nice and scenic at times and saves a ton of mileage over some of the other options and hassles.
I have lived about 10 miles south of Dulles Airport for the last 28 years and that is my escape route to go north or south out of the D.C. Beltway madness.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Drbolasky
Fogelsville, PA
Posted: 03/04/12 07:38am Link  |  Print  |  Notify Moderator
You're getting some good advice on "Just Say No" to I-95/495 anywhere around or near D.C. My recommendation is to take I-81 and pick up US-15 at Harrisburg......
Larry
A slightly different route would be I-81 to I-83 south, then Rt. 581 to Rt. 15. We've had better luck with that than going directly to Rt. 15 from I-81.
