RV.Net Open Roads Forum: Class C Motorhomes: Norcold refrigator
 > Norcold refrigator
Dusty R
Charlotte Michigan 48813
Posted: 02/23/12 06:05am Link  |  Print  |  Notify Moderator
Is there a way to adjust the temperature in the freezer and not the refrigerator, or the other way.
It's a Norcold N 611.
Dusty
CrazyTed
Hoollieville #214
Posted: 02/23/12 07:04am Link  |  Print  |  Notify Moderator
Not sure on that model but every one I've ever had only used one adjustment. The freezer gets cold first and the cold air migrates to the refrigerator side. Only adjustment I've ever found is in the fridge. Again, not sure on that particular model.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2010 Husaberg FX450 (Sold)
2015 Husqvarna FE350
2008 Triumph Rocket III 2300cc
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS (Sold)
2009 Jayco Seneca HD 36MS
j-d
Sunny Florida USA
Posted: 02/23/12 07:20am Link  |  Print  |  Notify Moderator
We have N811 and the setting controls fridge temp. Cooling actually happens more in the freezer, but the sensor looks at how much was conducted (those fins) back into the fridge.
Our freezer is colder when we open the fridge occasionally through the day. Doing that kicks the cooling unit on.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
Ivylog
Blairsville, GA and WPB, FL.
Posted: 02/23/12 07:38am Link  |  Print  |  Notify Moderator
NO
04 Monaco Dynasty 42' quad slide
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
Mocoondo
Chicago, IL
Posted: 02/23/12 07:45pm Link  |  Print  |  Notify Moderator
You actually ARE adjusting the freezer temperature when you adjust the temp control.
The fridge doesn't cool; the freezer does. Cold air migrates from the freezer down to the fridge through the cooling fins at the rear of your fridge box. A thermistor is mounted on one of the fins which tells the fridge to turn on or off depending upon when a certain fin temperature is reached in the fridge.
Old-Biscuit
Verde Valley
Posted: 02/23/12 08:14pm Link  |  Print  |  Notify Moderator
You can make minor adjustments based on where the thermistor is located on the fin and which fin it is installed on inside fridge section
Sliding thermistor up on fin will make unit cycle longer so fridge section can get colder (freezer also). Moving it down will cause the fridge section to be warmer.
Leaving fridge door open ('shelf surfing') and/or frequent opening of it will cause a warm fridge section and a much colder freezer section due to increased cycling of unit.
Dusty R
Posted: 02/24/12 06:56am Link  |  Print  |  Notify Moderator
I would like to make the freezer colder and the refrigerator warmer.
right now the refrigerator is about 40* and the freezer about 27*.
Dusty
Old-Biscuit
Verde Valley
Posted: 02/24/12 10:18am Link  |  Print  |  Notify Moderator
Dusty
[emoticon]
If you make the fridge any warmer you very likely will be throwing food away due to it spoiling.
Are you sure you didn't mean to say......make the fridge section colder?
I would think you would want BOTH colder based on temps you posted.
More thermistor UP on the cooling fin in back of fridge section.
Dusty R
Posted: 02/24/12 10:33am Link  |  Print  |  Notify Moderator
No, the freezer hardly keeps ice cream cold enough, if we turn it down things in the refrigerator freeze.
Dusty
GrumpyandGrandma
Where ever Grandma tells me we're going.
Posted: 02/24/12 11:39am Link  |  Print  |  Notify Moderator
BUy one of these, it really helps
Fridge fan
Grandma in front of her retirement home..
She lets Grumpy drive!!
