RV.Net Open Roads Forum: Class C Motorhomes: 99 Shasta Wiring Diagram
 > 99 Shasta Wiring Diagram
99ShastaOhio
Cincinnati
Posted: 02/23/12 07:55am Link  |  Print  |  Notify Moderator
I have a 99 Shasta 22 foot Class C that I need a wiring diagram for. My rear driving lights and side lights no longer work. Unfortunately, I came to close to a fence post and pulled the one of the back side lights off - I replaced it but now they don't work. This is on a E350 Econoline Chassis. Not sure if there is a fuse that controls just the back running lights - front running lights still work. Any help appreciated.
garym114
Bluff Dale, Texas
Posted: 02/23/12 10:13am Link  |  Print  |  Notify Moderator
Do you have the owners manual for fuse locations?
If not here it is. 1999 E350 Econoline
This is for the van but it applies to the stripped chassis. If you have fuses in locations the manual says the slot is not used the builder, Shasta, used the fuse location.
99ShastaOhio
Cincinnati
Posted: 02/26/12 07:58pm Link  |  Print  |  Notify Moderator
Thanks for the link but it didn't work - however did find owner's manual on line.
Don't see any additional fuses that aren't indicated in the Ford manual. Does anybody have a wiring diagram on any size Shasta Class C?
Thanks,
spacedoutbob
SF Bay Area
Posted: 02/27/12 12:59pm Link  |  Print  |  Notify Moderator
Your chassis may be older than a 1999, check the 10th digit in the actual VIN because it can make a difference on your Wiring Schematic. Good Luck. There may be another fusebox in a different location for your clearance lights also and RV accessories.
Bob
Good Sam Club Life Member
99ShastaOhio
Cincinnati
Posted: 02/28/12 07:30pm Link  |  Print  |  Notify Moderator
I found out it is actually a 98 chassis - does anyone have a wiring diagram? Thanks in advance.
Roger
Westronics
Redmond, WA
Posted: 02/28/12 10:36pm Link  |  Print  |  Notify Moderator
If it helps at all, sometimes the rear lights run off the trailer wiring, which would be a different fuse.
In my signature you can find the Ford motor home customer assistance number. Call it - they will help you. They have been extremely helpful the few times I called.
2002 Jayco Greyhawk 24SS, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV Tires
