RV.Net Open Roads Forum: Travel Trailers: Wall delamination
 > Wall delamination
Page of 5
Jerry9n
SE Michigan
Posted: 02/24/12 10:48pm Link  |  Print  |  Notify Moderator
Okay, here is what I know about delaminaton (so far). I have an HTT and could see some slight bubbling on the bunk ends. Since the company that made the trailer as well as the company that built the bunk ends were both out of business I tore into the ends from the inside. What I found was wet luan from leaks in the seals. You could literally follow the leaks. What separated were the plies in the luan. No where did the luan pull away from the fiberglass. It stuck tight. I scraped and cleaned and replaced areas of luan with new wood backing.
As a result I pressure tested my trailer using a furnace blower. The results were astounding. I ended up removing all the existing caulk and recaulked all the seams. The previous year we put Eternabond on the roof seams and all the roof penetrations and not one of them showed any leakage.
I have a couple of bubbles on the exterior that I am going to try to figure out a repair for when the weather warms again.
The best thing that I can say is even on a new trailer, have it pressure tested. If you do a search you can find some information on do it yourself testing with pictures. When a trailer with luan backed filon leaks, it will delaminate. Pressure testing is about the most positive way of finding leaks.
IMHO
TxTiger
North Texas
Posted: 02/25/12 09:02am Link  |  Print  |  Notify Moderator
PapPappy posted a response to the thread below that showed a great DIY way to pressure test for leaks.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25442617.cfm
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
pbohart
Portland, Oregon
Posted: 02/25/12 10:08am Link  |  Print  |  Notify Moderator
$100 for a SealTech leak test at just about any RV store. Takes an hour and I got a printout of 4 or 5 different spots that were leaking.
ProFlexRV and I rest easy.
Eternabond on the roof.
2010 Chevrolet Silverado 2500HD Diesel
2012 Jayco Eagle Super-Light 314BDS
TxTiger
North Texas
Posted: 02/25/12 12:20pm Link  |  Print  |  Notify Moderator
$100 is a deal. I would have thought it would have been much more based on the hourly rates I've seen posted.
TxTiger
North Texas
Posted: 02/25/12 04:39pm Link  |  Print  |  Notify Moderator
ExRocketScientist wrote:
I wear blue nitriles and have the soapy water on hand. Where the caulk just came out of the tube, I can do a fairly decent job. Maybe I just need someone else to use the caulking gun while I come right behind them smoothing it out.
This might make it easier. There appear to be some better ones at the bottom of the page.
http://www.amazon.com/dp/B0009F8936/ref=pe_110400_22836150_pe_epc_dt8
Almot
Vancouver BC
Posted: 02/25/12 07:08pm Link  |  Print  |  Notify Moderator
smkunder wrote:
Is all the talk about the fiberglass wall panels delaminating as common as it seems to be mentioned?
Yes, they do have delaminate issues sometimes. Not more often than rotten wooden frame under aluminum siding models, though. Which means - most trailers after 5-7 years unless you don't take steps to prevent it, or unless you camp in a middle of desert and always store it under roof when not in use. Because delamination of FG, same as rot of a wooden frame, is almost always caused by water ingress.
Repairs: In FG laminate you have to fix the laminate (frame is aluminum), in alum siding you have to open the siding, fix rotten wood frame and put siding back. The former is more difficult to fix on your own to esthetically perfect look, the latter is more difficult to detect (you don't know about rotten wood until it's well under way, sometimes going on for years). The former hurts mostly exterior look (bubbles), the latter is a structural damage.
smkunder wrote:
It seems that a person can be given many horror stories on which way to go on a lightweight trailer to the point of being more confused
FG laminate models are only marginally lighter than same model from the same maker made in wood/aluminum. If you want a "lightweight", you should look for those without slides and as small as possible.
smkunder wrote:
What criteria does most use to make the final decision?
They read, ask and toss a coin eventually. Many purchases are influenced by women, same as cars, and things like cabinets or carpet color can play a greater role than considerations of structure and maintenance. Also, buyers of any gender are influenced by a zillion of important and unimportant things like floor plan, exterior decals or how friendly is his local dealer.
smkunder wrote:
Is there really a good place to get reviews
No, because - read the above paragraph. You need to know what is important for you - not for others, and base decision on that.
Edit/added:
To correct myself: "Not more often than rotten wooden frame under aluminum siding". I should have said that under same weather conditions and with same flawed seam, same water ingress would more likely trigger the delamination than rot in a wood frame. Because plywood substrate is sealed between the block foam and FG coat, unlike wood frame that is better ventilated. Which doesn't mean that later the delamination would spread and destroy as much area of the siding as the rot would destroy the wood frame. I don't think there are reliable long-term data for either scenario. Again, - this all is assuming the water got in, in the first place. Prevention is the key.
* This post was edited 02/25/12 07:40pm by Almot *
rexlion
Broken Arrow OK
Posted: 02/25/12 07:38pm Link  |  Print  |  Notify Moderator
Almot, good point. Whether fiberglass gelcoat or aluminum siding, leaks are not "if" but "when," and both types can sustain costly, serious damage from water infiltration. Between the two types, the choice is six or a half-dozen.
Francesca Knowles
Port Hadlock, Washington
Posted: 02/25/12 08:51pm Link  |  Print  |  Notify Moderator
My trailer is more than 30 years old, and it doesn't leak. The notion that one must accept as a Cost of Buying the "fact" that all trailers/rv's inevitably leak is on its face ridiculous.
Who would buy a house with that "caveat"?
There are methods of construction that prevent leakage in rv's. Pay as much attention to that detail as you do to floor plan, and you'll be fine.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
StaceyE
Chicagoland
Posted: 02/26/12 07:08am Link  |  Print  |  Notify Moderator
hilandfrog wrote:
I really liked this guys site on things to do and check.
his link
Enjoy what you end up with.
Repo
Thank you for this link! We just bought a new TT and want to be sure to avoid leaks (our old TT had two). This is a perfect start to being sure we are maintaining correctly and taking care of it properly.
Tom and Stacey
DD Nikki (14) and Kate (9)
Wrigley, our big black dog
Almot
Vancouver BC
Posted: 02/26/12 06:40pm Link  |  Print  |  Notify Moderator
hilandfrog wrote:
his link
Yep. Good check-list for preventive maintenance.
RV is not a house. It's moving, vibrating, roof has no eaves and there is lots of screws, vents etc in roof and walls.
Yes, there are methods of RV manufacturing to prevent leakage - "the method", I should say. Because there is only one leak-proof method - molded shells like Scamp, Escape, Casita. It's used on small units only. In fact, it's not really "leak-proof", but rather a "rot-proof", because there is no wood framework or wood substrate under FG (though some models have wood around windows and doors). They are molded of structural fiberglass, like boats - top half is joined with lower half, with seam in the middle of the wall. There is no roof perimeter seam.
All other trailers need prevention and more prevention. If yours doesn't leak after 30 years with no prevention like seam sealing and thorough inspection of roof, windows and other suspects at least once a year, - you're one of rare exceptions. 30 year old trailer built by conventional methods sells for 1/10 of its original cost, the main reason is damages caused by leaks. 30 year old molded unit sells for 1/2 of its original cost, but they are small, not for everybody's lifestyle.
Page of 5
 > Wall delamination
