RV.Net Open Roads Forum: How Many Receivers Can Be Used With a Dish Tailgater
 > How Many Receivers Can Be Used With a Dish Tailgater
want-a-be
Indiana
Posted: 02/23/12 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Can you use more than one receiver with the tailgater? Also is there a way to use a splitter to get the same program on the back TV has what is on in the front.
Thanks for any comments!
michelb
Ottawa, ON, Canada
Posted: 02/23/12 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I'm not really familiar with the Tailgater but any dish with dual LNB can be used with up to 4 receivers with a multiswitch.
As far as watching the same content on the back as the front, assuming you're using an external receiver (i.e. not the tuner in the front TV), the selector switch that comes with most motorhomes will allow the same source to be watched on front and back.
wildmanbaker
Kennewick, Washington
Posted: 02/23/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the Wineguard Carryout? If it is, 2 is the max it will support, but they must be watching the same sat.
Wildman
TechWriter
On The Road
Posted: 02/23/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
want-a-be wrote:
Can you use more than one receiver with the Tailgater?
Nope.
You don't need a splitter. The VIP211k has HDMI, component, composite, and RF outputs. So you connect one TV to HDMI and maybe connect the RF to the coach's cable system & the other TV.
* This post was edited 02/23/12 11:01am by TechWriter *
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
BB_TX
McKinney, Texas
Posted: 02/23/12 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have not bought a Tailgater (yet) but it is my understanding it only has one coax connection from it. That would go to a single ViP211k receiver.
I do have a ViP211k receiver (with a basic tripod dish). I simply connected the existing trailer coax (that originally connected to the park cable) to the RF output of the ViP211k receiver. The bedroom TV gets the same program selected for the living room TV. Living room TV is connected to the HDMI output of the receiver.
Wherever I happen to park
Posted: 02/23/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
In theory you can add receivers till your wallet is empty. All you need is the proper SWITCH. HOWEVER the Tailgater is a "Dome" class antenna (Dish 300 class) and this means that it can only see ONE satellite at a time.
So if you want to watch say NASA while partner watches "Days of our Life" ...
no problem
But if partner wants to watch say Hallmark.. Big problem.
Kiwi_too
Western, WA
Posted: 02/23/12 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
no problem
. . . because the first two are on the same satellite and the last is on another satellite, Correct?
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
wildmanbaker
Posted: 02/24/12 10:49am Link  |  Quote  |  Print  |  Notify Moderator
That is true. To view more that one sattlite at a time, you need more than a single LNB, on the antenna.
Fred_n_Jo
central MO, USA
Posted: 02/24/12 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Not true, the Tailgater logs on to 110, 119, & 129 (if in sight) for signals to the 211 receiver.
2011 HH DA 349 RSB 5th
2011 F350 Lariat 6.7L PSD CC SB 4X4
18K PullRite SuperGlide & 50 gal Titan fuel tank
our places camped Map
Dutch_12078
Great Sacandaga Lake, NY
Posted: 02/24/12 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, true... The Tailgater only "sees" one satellite at a time, and re-aims itself to the other two satellites as needed based on the channel selected.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
