N6761U
Eureka, CA
My nephew just bought an 06 396 rdds 5w. I have to go to Bend Or. next week and pick it up for him. Does anyone out there have one and well does it pull. And have you had any problems with the RV itself.
Thanks
dblr
Newark De
We had a 06 Open Road and it was a nice unit but we did have frame issue with it, it cracked near the bedroom and also the pin box failed got it fixed and got rid of it. I had big hopes for this manufacture but they could not survive.
Towed fine we had 3 axles on this one, good luck but check the pin box.
05 F350
2010 Cedar Creek 36RE
N6761U
Eureka, CA
Thanks for the info, only have to haul it home about 600 miles. Then it will be parked and used fulltime while my nephew builds his second stick and brick.
D&E Johnson
Ontario, Canada/Quartzsite, Arizona
probably doesn't help, but we have a 2007 Open Road 38' 359RL3S- when towing, you don't even know its behind you. Very smooth. Have not had a problem with anything in or outside the trailer. Bought new in May 07. We use it for 5 months in Arizona each winter..good product.
Dona and Elvin
2010 Dodge Laramie 3500 4x4 Mega cab-in Pearl black/tan
2007 Open Road 359RL3S
2004 Yamaha Kodiak 400 ATV
cabanaman
florida
I also have an 07 open road,bought jan of 07. It tows great and the frame and pinbox show no signs of trouble.We fulltime in it and it is holding up just fine.As long as the tires are not falling apart you should get it there and it will do the job.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
cabanaman
florida
N6761U wrote: Thanks for the info, only have to haul it home about 600 miles. Then it will be parked and used fulltime while my nephew builds his second stick and brick. Well did you make it?
Ramair
Idaho and Texas
We have an 08 358RL4S and we have had no issues pulls very nice and well built. No issues with the frame or the pin box. good luck and enjoy!!!!!!!
Andrew & Donna Reyes
2012 Georgetown 378 XL
