RV.Net Open Roads Forum: Tech Issues: Cable length for Solar
 > Cable length for Solar
Crazy Ray
Monroe,La
Posted: 02/23/12 12:12pm Link  |  Print  |  Notify Moderator
Talking Solar (405W) from old MH and putting in 07 Bounder. My question is I have to go 25 feet with #2 cable from combinder box to Controller (TriStar 45). Will #2 Cable be OK or do I need larger Cable? I have read so many pages on Solar installation and still lost. Thanks
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
JohnnyT
On The Road
Posted: 02/23/12 04:16pm Link  |  Print  |  Notify Moderator
Moved from class A forum
2oldman
Palm Springs
Posted: 02/23/12 04:28pm Link  |  Print  |  Notify Moderator
you're fine.
MrWizard
Traveling
Posted: 02/23/12 04:32pm Link  |  Print  |  Notify Moderator
moved to tech issues
Radiate The Happy
1997 F53 Bounder 36s
MrWizard
Traveling
Posted: 02/23/12 04:34pm Link  |  Print  |  Notify Moderator
#2 is fine .. your good
I've got mine wired with number eight from combiner box to controller and #4 from controller to batteries
mena661
Posted: 02/23/12 04:40pm Link  |  Print  |  Notify Moderator
2oldman wrote:
you're fine.
X2
Trojan L16 6V's 740 Amp-hours
time2roll
Posted: 02/23/12 04:49pm Link  |  Print  |  Notify Moderator
#2 seems fine. I would not spend money to go above #6. Although #2 will be fractionally better.
I calculate .5 volt drop with #6 and .2 drop with #2. Once the PWM controller is in absorbtion I don't think it matters a bit. About 3% power loss in bulk mode if that is enough to matter.
675w Solar pictures back up
Crazy Ray
Monroe,La
Posted: 02/23/12 04:57pm Link  |  Print  |  Notify Moderator
Thanks to all. I tried to get this into Tech and could not get into Tech. I had about 60 feet of # 2 given to me.
msiminoff
Silicon Valley, CA
Posted: 02/23/12 05:06pm Link  |  Print  |  Notify Moderator
With the 2ga you will have less than 1% voltage drop... You could use 6ga wire and still only have lose 2.5%.
If you haven't purchased the wire yet, you can save yourself a few bucks by using 6ga (which by the way has an ampacity rating of 102A).
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
CA Traveler
The Western States
Posted: 02/23/12 06:01pm Link  |  Print  |  Notify Moderator
You're fine and can use smaller wire as posted above. But 2 suggestions:
1. Post # panels, panel info, wire length of each panel to the combiner box, plus the 25', and the length to the batteries. You'll get more information.
2. Consider if you might instead use a MPPT controller or upgrade in the future. In that case the wiring considerations are different and you may want to use those considerations even with a PWM contoller.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
750 Watts Solar MPPT 60 Controller
2004 Honda CR-V
Bob
