bgant4
Naples, Fl
I have an 2008 GMC duramax 2500 4wd. When I am towing my rv what is the max the trans should reach? It normaly runs about 170. Where is the danger zone?
HTT to be?
Southern Wisconsin
Depends on who you ask. I like to stay below 200*, but anything above 225* will surely start to cause premature breakdown of your fluid.
2007 Jayco 23B
2009 E350 Ford Club Wagon 5.4 w/ tow pkg
Equalizer hitch, Prodigy P3 brake controller
Buddy 125 Scooter-FUN!
1997 Coleman Sunridge- Served us well for 11 years!
tvman44
Southwest Louisiana
I like to see under 200 or if over just for a very short time.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
boogie_4wheel
SLC, Utah
200 would get me to actually start watching it.
210 would have me start changing driving to help cool.
220 I would stop and idle to cool
I have my CTS set to alarm me at 220.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
skipnchar
Topeka or somewhere else
There really IS no danger zone as such. Your temp will likely very based on the ambient temperature and the difficulty of the job it's being asked to do. ON a hot day towing a heavy load up a steep hill it will run a lot hotter than a winter time cruise down a level road. The DANGER comes from running at extreme temperatures for an extended period of time but a five or ten minute jump while climbing a mountain pass will usually not harm anything when temps hit 220 or 230 degrees. If you ran that warm WITHOUT working it hard or for longer time periods it would be time to do a fluid flush in the long term or pulling over and letting it idle in park for a while to cool down.
12th Man Fan
Flower Mound , Texas
I have an 09 Dually GMC CC and when pulling in the summer I frequently run in the 200-210 range.I have seen it as high as 219 but only briefly. I have talked to the dealer and they would not give me an exact temp but they said those temps wer not a problem. The truck will let you know before you do any damage. Just change your fluids on the recommended mileage.
I often wonder how the transmission fluid can run cooler than the water when the fluid is circulated through the raditor. My water temp is steady at 210. It fluctuates some but when the jet propelled fan come on it cools back down pretty quick.
2009 GMC Duramax 4X4 DRW Crew
2005 31SKT Alumascape
boogie_4wheel
SLC, Utah
Your radiator temp is not 210, just your engine temp. The radiator temperature is almost always cooler than the engine temp. The radiator/trans water-to-water cooler actually does a pretty good job of displacing trans heat.
MARKW8
Akron OH
Pulling a heavy trailer you shouldn't use 6th gear at all. 6th will allow the torque converter to unlock on an Allison, which causes excessive heat. Even if it holds 6th ok you shouldn't use it.
Mark
crickeydog
Marietta, Ga.
Your tranny temp sounds a bit high to me on average. Our tranny temp seldom ever gets above 150 degrees in 6th gear at 60 MPH even on a hot day towing our 14K 5'er. Stop & go traffic will push the temp close to 200. I've read any temp over 200 degrees for any length of time on the Allison can be hard on your fluid & tranny.
Happy camping!!! See y'all down the road!!!
USAF RETIRED. "EITHER LEAD, FOLLOW, OR GET OUTTA THE WAY"!
PULL DOGS:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT "THE SILVER FOX" PRIMARY
2000 DODGE 3500 QUAD CAB DRW CTD LARAMIE "THE ROAD TRAIN LOCOMOTIVE" BACK-UP
2004 HOLIDAY RAMBLER PRES. 30 SCD 5'ER
04FX4
Kelowna, B.C
Your temps are fine. 220 is not abnormal to see while climbing up steep hills. Do a search on the internet. Just make sure you do your maintenance .
