RV.Net Open Roads Forum: Beginning RVing: Water Heater questions?
 > Water Heater questions?
AC09
Yuma
Posted: 02/23/12 03:59pm Link  |  Print  |  Notify Moderator
Since the water heater never worked on any of my previous RVs I never had to be to concerned with this (Lots of REALLY cold showers) Anyway Do you keep the water heater on the entire time you are camping or turn it off at night and back on in the morning? Also, do you drain it after every trip?
robsouth
Metro-Atlanta, GA
Posted: 02/23/12 04:09pm Link  |  Print  |  Notify Moderator
I leave it on. Never know when you might want to wash your hands. We mostly run it on electric so no propane use involved. About draining, if it is going to be a while before the next trip, or it is winter time, I drain it. If we are going out the next weekend or two, I don't drain it, even though draining only takes a couple of minutes.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
enblethen
Moses Lake, WA
Posted: 02/23/12 04:17pm Link  |  Print  |  Notify Moderator
I shut ours down while we are daytripping in toad, at night (first one up turns on coffee pot and the water heater), and while on the road.
It normally only takes 10-15 minutes to come to temperature.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Son of Norway
Denver, Colorado
Posted: 02/23/12 04:21pm Link  |  Print  |  Notify Moderator
I turn it on first thing in the morning and then turn it off at bedtime. We drain the entire water system after every trip. Too bad about the cold showers, you should have fixed it!
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
NanciL
Bakersville, NC,/Key Largo FL
Posted: 02/23/12 04:26pm Link  |  Print  |  Notify Moderator
We turn ours on about twenty minutes before we want to take a shower, and my wife turns it on for about fifteen minutes prior to doing the dishes. Otherwise we leave it off.
Jack L
Jack & Nanci
2oldman
Palm Springs
Posted: 02/23/12 04:29pm Link  |  Print  |  Notify Moderator
Same question yesterday
bikendan
Camano Island, Wash.
Posted: 02/23/12 05:21pm Link  |  Print  |  Notify Moderator
Jack L
pretty much what we do, because we have to heat it with propane, since we rarely have electric hookups. the water stays hot for quite awhile. that way it doesn't keep using propane while we're gone.
if we had electric hookups, then we'd switch to electric and leave it on.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
edatlanta
Maplesville, AL - Home Base
Posted: 02/23/12 06:04pm Link  |  Print  |  Notify Moderator
When I'm hosting with free electricity I use electric for my hot water. At my home base I use propane because it is cheaper than my home base electric rates. I leave it on all the time either way. I full time and my home base has a 150 gallon external propane tank so I don't have to handle the smaller tanks all winter.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
coug
Eastern Washington
Posted: 02/23/12 07:07pm Link  |  Print  |  Notify Moderator
We always have it off until just before we know we will need it. We are never around during the day and only use it for showers in the morning.
2010 Arctic Fox 22GQ
2011 Chevy 2500HD LTZ
old guy
Oregon (pronounced Or e gun)
Posted: 02/23/12 07:11pm Link  |  Print  |  Notify Moderator
some city water or private wells have smelly water so drain the tank would be advisable. if not you will smell horribly after a shower from that tank.
