RV.Net Open Roads Forum: Tech Issues: Voltage Spikes!!!
 > Voltage Spikes!!!
Page of 6
sdagro
Independence,LA
Posted: 02/24/12 10:44am Link  |  Print  |  Notify Moderator
Does not do it all the time which makes me think either loose neutral or cut wire which has all been checked and eliminated.
Mandalay Parr
Phoenix, AZ
Posted: 02/24/12 10:45am Link  |  Print  |  Notify Moderator
Maybe a problem with your power cable.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
MPD56
Canada
Posted: 02/24/12 11:07am Link  |  Print  |  Notify Moderator
Salvo: He has a 50 amp system and if the neutral opens, he could possibly have higher voltages, without the neutral the voltage wouldn’t be balanced and large loads would have higher voltages.
Not sure what make of 50 amp transfer switch the OP has, but some have electrical open neutral protection on the generator side and not on the shore power side (example the IOTA ITS ITS-50R).
The OP seems to have an intermittent problem, which makes it hard to verify and the members to only guess. The OP could try, only using a 50 to 30 adapter while he is troubleshooting so if he is loosing the neutral at lease he isn’t burning up more appliances and they simply wouldn’t work if he did loose the neutral.
Yaj
The Milky Way Galaxy (Fort Myers, FL)
Posted: 02/24/12 11:13am Link  |  Print  |  Notify Moderator
What he said. Almost has to be a neutral problem.
I run a 240 volt electric space heater and I had one that when it cycled itself off it would do something that would pop my surge protector. I changed to a different heater and have had no problems since. Just thinking it could be a problem with a certain appliance?
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser, 2 bikes,
1 DW, 2 kids.
I wasn't thinking this far ahead!
camperpaul
Wherever I park my travel trailer
Posted: 02/24/12 11:15am Link  |  Print  |  Notify Moderator
Intermittent problems can be a real pain...
When you star trouble shooting, you can't find anything wrong but it fails when you least expect it...
e.g.
A friend's car engine wouldn't start (acted like dead battery), so I opened the hood to check the battery voltage and all of the electrical stuff started working. I had him try the engine and it started normally...
It turned out there was a wiring harness that was being moved slightly by the hood hinge thus allowing a defective connection to make contact only when the hood was open.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
Salvo
California
You have a 230V receptacle for the microwave? With microwave on, I would expect voltage to drop at that receptacle.
sdagro wrote:
Every time problem occurs and I check the voltage at receptacle w/multimeter voltage is always 230-238v.
MrWizard
Traveling
Posted: 02/24/12 11:17am Link  |  Print  |  Notify Moderator
replace your shore cord
either the molded on connector has a broken neutral OR the neutral wire is broken inside the cord
Connected thru Verizon with HotSpot WiFi using a Samsung S4 and/or Novatel 2200 MiFi
Yaj
Posted: 02/24/12 11:30am Link  |  Print  |  Notify Moderator
Makes sense.
Wherever I happen to park
Posted: 02/24/12 11:37am Link  |  Print  |  Notify Moderator
Spike, A very short "peak" in voltage, on a scope trace it looks like a nail sticking up (hence the term "Spike")
Surge, A much longer sustainted increase in voltage, often lasting a second or more.
Surge supressor strips (The common outlet strips) do nothing for a surge cept sound like a firecaracker as the MOV's in them explode
Real surge supressors (like the progressive dynamics power line guardian devices) will shut off pwoer to your rig in a surge.
BOTH supress spikes.
A circuit breaker will NOT trip due to high voltage, nor will a current spike trip it less it is many times it's rating. But a current SURGE will.
There are hints as to recommendations in this..
My suggestons:
A power guard, Like the ">n-US
NOTE: an open neutral will cause odd voltage fluxations epically on a 50amp rig
Home is where I park it.
sdagro
Independence,LA
Posted: 02/24/12 11:59am Link  |  Print  |  Notify Moderator
When I checked voltage at microwave it read 230v. No it is a 110v receptacle. That's why my microwave is "no longer with us".
Page of 6
 > Voltage Spikes!!!
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
