RV.Net Open Roads Forum: Class B - Camping Van Conversions: Portable Air Compressor
 > Portable Air Compressor
Itaricans
Platte City, Missouri.
Posted: 02/24/12 12:32pm Link  |  Print  |  Notify Moderator
Hello guys, we are going to Fl. this coming March, and I want to take with me a portable air compressor for emergencies, I've got road assistance and cans of slime, but our PW has those air coils, plus if one tire is just low I'm not going to call someone and wait, my wife gave me some time ago a Craftman tire inflator, that was very good, I used it in my car for many years until it finally died, but for these tires I'm going to need something bigger and stronger, anyone has any suggestions? Thanks for any help. Latter. Louie.
Itaricans. man can not live on bread alone....(pizza, burgers,and ribs help a lot)
khalsey
manhattan,il
Posted: 02/24/12 12:51pm Link  |  Print  |  Notify Moderator
12 volt air compressor, 44% off. Free Shipping, Today only!
http://www.amazon.com/dp/B000BM8RT8/...QRF248Y5N86C0E
Here is one, good deal today.
NewsW
US
Posted: 02/24/12 01:16pm Link  |  Print  |  Notify Moderator
I assuming you are dealing with a class B that need 80psi cold.
Get a good sized one that gets you 120psi or so in case you have to inflate it hot (e.g. to 90psi).
Plus it need to be good sized to deliver the volume --- a 12v job is limited by the energy the socket can pull, often set at 15amp or less.
Devocamper
West Haven CT
Posted: 02/24/12 01:22pm Link  |  Print  |  Notify Moderator
look into a co tank, most of the small compressors struggle to make 80 psi.
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
Bob/Olallawa
Kitsap Co, WA
Posted: 02/24/12 02:10pm Link  |  Print  |  Notify Moderator
This compressor does not struggle, it just takes a while depending on many lbs to air up a tire. Using it for my air bags it is very fast to the 50 lbs I run at. http://www.viaircorp.com/ sorry I don't do links well.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
jjson775
Posted: 02/24/12 02:13pm Link  |  Print  |  Notify Moderator
We carry a Craftsman 120 V portable compressor in our PW Excel that works perfectly when you are plugged in. Easily pumps the tires to 80 psi required and has an inflator connection on the hose. We also carry a cheap 12 v compressor for emergencies or when we camp unplugged. You will need an extension to reach the air bag fittings on the bumper.
Jim
1775
NY
Posted: 02/24/12 10:53pm Link  |  Print  |  Notify Moderator
Lowes sells a 12 volt/120 volt 120 psi tire compressor with sufficient psi to inflate 80 psi. It is nice as it goes both ways. I have been looking at a lot of small compressors as the small shop compressor that I have been carrying takes up way too much room in my Class B RV's limited storage area. This one at Lowes by Kobalt (which is Lowes own label) looks like a good one and gets good reviews. Here is a link.
If you need to fill from flat to full this may not do it or may not do it very fast, but to add several pounds to bring the tires up to psi, this will do fine.
Once the warm weather comes back and I de-winterize, I plan to get one.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
WaterDaisy
Beaufort
Posted: 02/25/12 11:08am Link  |  Print  |  Notify Moderator
We've had this one for a couple of years and have been happy with it:
http://www.amazon.com/Industries-MV50-SuperFlow-High--Compressor/dp/B000BM8RT8/ref=sr_1_3?s=automotive&ie=UTF8&qid=1330193292&sr=1-3
Neal 05C210P "Daisy II"
"fast enough to get there.....slow enough to see" JB
Horizon170
Jefferson, GA
Posted: 02/26/12 11:46am Link  |  Print  |  Notify Moderator
Remember that most of the 12 volts compressors are for limited duty. Keep for emergency use only and not as your only compressor. 110 volt for home use.
Usually when you have a leaking tire it's a nail or screw. Easy to plug temporarily. The key word here is TEMPRARILY. Once you get to civilization let a qualified Tire Store break it down and patch if possible.
Don't use Slime as repair shops hate that stuff.
I bought a couple of 12 volt compressors from HF (10 bucks) and although I don't expect them to last forever one use is cheaper that a service call.
Marvin
My Roadtrek
Tucson, AZ.
Posted: 02/26/12 01:46pm Link  |  Print  |  Notify Moderator
I've never seen a 12 compressor last long doing much heavy duty tire inflating.
Buy a small 110 volt compressor if you have a generator. Oil ones are better that oilless, but if you plan on using it to blow out the RV lines, get an oilless. A compressor that uses oil will have a small amount of oil mixed with the air, and that is not good in the lines, tanks, and water pump.
