Wanderman
New York
Funny Camper,
I have been speaking with the importer/manufacturer about other colors. They seem reluctant to change. Seems pretty dumb to me. I mean Bright Red as the ONLY available color? Whose decor does that match? White/Off White Black...seems like common sense.
Rich "The Wanderman"
1991 Aero Cruiser 23RBa
Read All about my Disasters and Triumphs at:
http://www.thewanderman.com/
FunnyCamper
Southeastern
someone must be colorblind or something
does seem strange that the basic normal colors aren't used. hmm
LTCLarry
Maggie Valley, NC
Ok, I'll bite ...what is a ceramic heater.....?
Wanderman
New York
TRUE!
They manufacture a much larger unit on a stand...looks like the big dady version of the small one and it comes in 8 colors.
of course, since the housing is metal (like on an inexpensive BBQ) you could easily paint it whatever color you like.
But you shouldn't have to!
Wherever I happen to park
I do have concerns about the wires in the motor home.. Back before I took steps to prevent it sometimes my wife would plug into the wrong outlet, instead of the dedicated 20 amp, 12ga fed, I put in specifically for the heater she'd hit the OEM 15 amp next to it (NOTE that they are a different color to make it very easy to tell the difference, BLACK is the high power, the low power is white)
Within an hour I'd smell hot wires.
Not a good thing.
I never smell hot wires when she plugs it in right (Some duct tape over the 15 amp made it hard to plug in there)
RustyFairmount
Michigan
I use 2, set to low (600w). The furnace is used to supplement the electric heaters, if/when power fails.
pianotuna
Regina, SK, Canada
Hi,
I don't use ceramic--I prefer thin wall and 1/2 size oil filled units.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
gotsmart
Aberdeen, WA
I use a Pelonis NTK15A, Ceramic Safety Furnace, White as my primary heat source. I have a 2nd one, NIB, as a backup. I have it sitting 4 inches above the floor on a stainless steel (tent camping) cook pot that has a flat, locking cover - to raise it a little above the cold air sinking to the floor. When it is below 41F outside I run it on High (1500W) with temperature set to max. When it can't keep up, I use my propane furnace as a seconday heating source - to maintain 65F at night and 70F during the day. Above 41F I set the space heater to Low (1000W) and I reduce the tempurature setting. This little space heater can easily bring the temp inside the rig to 85F (relative to the outside tempurature). If I leave it on High in the morning and it gets to 55F-60F outside then it can be 80F in the rig when I return - and I end up running my Fantastic Vent to dump heat. I wish it had a real thermostat.
When I run my 1600W hair dryer, I turn off the space heater until I'm done. My MH is 30 amps. I don't feel like overtaxing the system - or risking overtaxing the system.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
Dakzuki
Carnation, Wa, USA
hilldude wrote: The ones I have used are either to hot or to cold.we use a Lux thermostat from Amazon does a great job Link
I have one of those too. Works great.
2011 Itasca Navion 24J
95 Chinook Premier
beemerphile1
I'm 57, I'm not a
LTCLarry wrote: Ok, I'll bite ...what is a ceramic heater.....?
- Soren Kierkegaard
