RV.Net Open Roads Forum: Toy Haulers: Anyone Removed this Keystone Raptor Part?
Search only in Toy Haulers
 > Anyone Removed this Keystone Raptor Part?
bkirkpatrick
Brea / Orange County, CA
Posted: 02/24/12 02:05pm Link  |  Print  |  Notify Moderator
Anyone every removed this Keystone Raptor Part? It is a tray in the passenger side main compartment. As you can see, it just holds "stuff". It is made of plastic but in order to get it out, I have to remove a bunch of caulking and metal channel that is screwed on top of the plastic rim/out edge. I can't see it from the bottom of the Raptor because it has that black foam paneling on it. I am just curious what the cradle looks like because I would like to drop it down and add some more batteries there.
Raptor - Modifications
EricRobinson8
Fountain Valley CA.
Posted: 02/24/12 02:18pm Link  |  Print  |  Notify Moderator
Sorry, I haven't done that but was thinking about batteries there also. Please post pics if you do it.
Thanks
2006 F-250 CC PSD 4X4
2007 Raptor 299MP
Pullrite Superglide
Sprinks542
Western Pa.
Posted: 02/24/12 05:20pm Link  |  Print  |  Notify Moderator
If adding batteries there, how would you vent them outside? Always thought batteries needed vented in this case.
08 Ford F-350 SD PSD CC
10 322 Fuzion Touring Edition II
07 Can-Am Outlander 800
08 Can-Am Renegade 500
bkirkpatrick
Posted: 02/24/12 05:47pm Link  |  Print  |  Notify Moderator
I would drop the bottom out of it and lower it about 4-6" using steel angle (creating a cradle). Right now it is 13-14" deep and needs to be a little deeper. I will fab up a top and make it a sealed area with the bottom either being completely exposed or vents added to it.
Doughboy12
Minnesota
Posted: 02/27/12 10:23am Link  |  Print  |  Notify Moderator
…and I thought I brought a lot of stuff with me…kind of shows the adage, the more room you have the more stuff you bring.”
I figure if I have it bring it.
Better to have it and not need it than need it and not have it.
Now, back on topic...sorry.
Jimbo480
Gilbert AZ
Posted: 02/27/12 11:09am Link  |  Print  |  Notify Moderator
I'm pretty sure that's meant to be a cooler to hold ice.
2011 Chevy 2500 HD Duramax
2006 Starcraft 23SBS
Drawtite WD Hitch
2011 Nights spent camping = 25
sptrucksbyed
Bella Vista,CA
Posted: 02/27/12 11:13am Link  |  Print  |  Notify Moderator
I see you already have 4 6 volt batterys , how many are you going to have when you finish adding these ??
2012 Ford F-350 DRW CC 4x4
2011 Raptor 4014LEV
2 Yamaha Raptors
2 Yamaha Banshees
2008 Rhino
2011 RZRS
bkirkpatrick
Posted: 02/27/12 11:53am Link  |  Print  |  Notify Moderator
I am relocating two but will upgrade to six.
BigJon05
Central Valley CA
Posted: 02/27/12 12:15pm Link  |  Print  |  Notify Moderator
Do you keep the other two in the front next to the generator? I would imagine your raptor is very similar to mine in the front area.
2007 3924 Raptor
03 F350 PSD longbed, 6" fabtec, BFG 35, airbags and compressor
09 Can-am Outlander 800 max xt ltd
07 Can-am Outlander 650 max xt
bkirkpatrick
Posted: 02/27/12 12:21pm Link  |  Print  |  Notify Moderator
. Yes, my master plan is to get them out of there and to get them back to that area from the original post. I am also toying with the idea of putting 4 of the batteries in the battery compartment. Another Raptor owner did it (WildBill?) by dropping the bottom out and moving things around.
