RV.Net Open Roads Forum: Tech Issues: Magnum ME 2012 Inverter/Converter
 > Magnum ME 2012 Inverter/Converter
CA Traveler
The Western States
Posted: 02/24/12 03:24pm Link  |  Print  |  Notify Moderator
While the rig is in storage I have no AC power and the Magnum draws 0.3A DC. There is no switch to disconnect it from the battery. Besides adding a switch is there any way to reduce the draw?
That draw will discharge the batteries to 50% in 30 days and so I will add a switch if that is my only option.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
750 Watts Solar MPPT 60 Controller
2004 CR-V and 2014 Grand Cherokee
Bob
Corkey05
Washington State
Posted: 02/24/12 03:31pm Link  |  Print  |  Notify Moderator
I have the same inverter.
Mine has a control panel on the inside of the coach. The panel has a push button to turn the inverter on and off. just above it is another button to turn off the charge from the inverter.
The switching button has a light to show if it's inverting, .. the light is off if you push the button to turn it off.
Hope this helps.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
time2roll
Posted: 02/24/12 04:01pm Link  |  Print  |  Notify Moderator
My Xantrex draws enough with the inverter off and the screen blank to drain the battery in a few weeks. I remove the fuse in the 12v positive cable to cut all power.
I recommend a switch, fuse or battery cable for disconnecting completely.
675w Solar pictures back up
MrWizard
Traveling
Posted: 02/24/12 03:39pm Link  |  Print  |  Notify Moderator
install an inline fuse on the battery cable
or use a very heavy battery disconnect switch
Radiate The Happy
1997 F53 Bounder 36s
CA Traveler
The Western States
Posted: 02/24/12 03:42pm Link  |  Print  |  Notify Moderator
Inverting was off when I checked the draw. The display also says it's off! Say what? The display shows off but you can read the display, so off is really what - almost off???
Any yes all input helps and I'll recheck all buttons.
BFL13
Victoria, BC
Posted: 02/24/12 03:45pm Link  |  Print  |  Notify Moderator
With our set-up the easy way is to remove one of the inverter's wires from its battery post. Won't that work for the OP's rig?
--the Trimetric monitor does need power from the battery to show anything. it has its own little fuse in its pos wire at the battery you can take out so the Trimetric then draws no power
* This post was edited 02/24/12 04:03pm by BFL13 *
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Corkey05
Washington State
Posted: 02/24/12 04:03pm Link  |  Print  |  Notify Moderator
Your display is reading DC amps drawn by a load not controlled by the disconnect switch. It will be a 12v DC load and not the standby load of the inverter When you turned it off, it goes out of standby.
Is your AquaHot off or in standby?
Do you have solar and your panels covered? (in the shade).
Those are two questions that seem to crop up a lot, but it could also be something else.
liborko
Surrey, B.C.
Posted: 02/24/12 04:22pm Link  |  Print  |  Notify Moderator
A high performance circuit breaker & manual disconnect:
ETA high performance CB
I have one of these rated 250A between the batteries and a inverter/charger.
christopherglenn
Near Yosemite
Posted: 02/24/12 08:31pm Link  |  Print  |  Notify Moderator
The propane detector has a draw also, if you don't already have a disconnect, now may be a good time for one.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Sailbad
Bernardo, New Mexico or Quartzsite
Posted: 02/24/12 09:45pm Link  |  Print  |  Notify Moderator
I also run the Magnum 2012. When it is turned off it draws 0 amps. What you are seeing is a DC draw in your rig. Probably the propane detector, or CO alarm. It's not the Magnum. I would add a DC switch to shut down all draws from the batteries.
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
Keep Your Powder Dry....This Ain't Gonna Be Fun
