GLaidlaw
Toronto, Ontario, Canada
Wonder if anyone knows if Bell has finally moved to the new satellite cutting off all reception in the US and specifically northern Florida. Tried to find the signal but no luck. Usually takes me 1 minute but nothing this time. Lots of wrong satellites so I know the technical system is working. Guess it is over to Shaw when we get back.
Macktee
Canada
What dish system are you using. ie tripod, moto-sat, winegard traveller? When was the last time you used it. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
GLaidlaw
Just using a tripod with a standard bell dish.Used it 2 yrs ago in Florida. Worked well. Wanted to know if anyone else was having trouble.
D&E Johnson
Ontario, Canada/Quartzsite, Arizona
maybe you should switch to shaw. We have used ours in Arizona for the last eight winters..we have our fifth wheel listed as our cottage with them. If we need help while in Quartzsite, Shaw has a contact in Yuma and they will send the repairman out to us-no charge.. They have been super to work with and no contract.
As far as the Bell satellite, I have no idea!
Dona and Elvin
2010 Dodge Laramie 3500 4x4 Mega cab-in Pearl black/tan
2007 Open Road 359RL3S
2004 Yamaha Kodiak 400 ATV
cmsm
Calgary, Alberta, Canada
We are using our Bell satellite in Yuma, Arizona. We have a better signal here than we had at home, although we can't get sat82, only sat91. We are using a tripod. It took about 20 minutes to get the signal - it's only the second time we have set up the system. There are 4 other Bell systems being used near us in the park.
Macktee
Canada
Like CMSM, We have used Bell on our RVs in Canada and the US for many years. I am sure if you play with it more you will get it. Mine is on Moto Sat and no problem when I am in AZ. Macktee
TrickyRicky
Riverview NB Canada
Had problems finding a signal in Tampa area last Friday and gave up thought it was too many trees. Moved to Cedar Key Tuesday and again could not find signal had the system set on Sat 91 and transponder 11 normal procedure had a signal on the external meter but nothing on the tv tried setting it on transponder 10 and there it was working fine now but no signal on transponder 11. Give it a try on a different transponder worked forme.
2005 National T370 Tropical Cat 350
A Cocker Spaniel "Tucker" a Cavalier King Charles "Lilly
and us Elaine & Rick
frank-2
Ontario
Right now I am in Mission, Texas and I am having very little problems getting my Bell to work they are some channels that I cannot get most of them do come in my brother-in-law is right next to me he is using a tripod and I have the Wingard carry out but they are few channels that I do not get I think maybe I'm just too far south
moisheh
North America
Shaw has coverage even into Mexico. They will give you tech support in the USA. If Bell finds out you are in the USA they will suspend your service. If you drive through a Snowbird park and look at the Canadian dishes Shaw has about 90% of the customers. The signal is as strong as in Canada and you will get all the channels. Bell's customer service is a legend but not a good legend. The WORST service in the industry. Shaw has ssrvice problems but they do try. Bell is arrogant.
Moisheh
Macktee
Canada
TrickyRicky wrote: Had problems finding a signal in Tampa area last Friday and gave up thought it was too many trees. Moved to Cedar Key Tuesday and again could not find signal had the system set on Sat 91 and transponder 11 normal procedure had a signal on the external meter but nothing on the tv tried setting it on transponder 10 and there it was working fine now but no signal on transponder 11. Give it a try on a different transponder worked forme.
Tricky, did you do a check switch, that might help. Macktee
