RV.Net Open Roads Forum: clearcoat on front and rear fiberglass caps peeling on top
 > clearcoat on front and rear fiberglass caps peeling on top
lj2654
Weeki Wachee, Florida
Posted: 02/24/12 03:59pm Link  |  Print  |  Notify Moderator
I was wondering if anyone has done their own sanding and reclearcoating the top front and rear caps on a motorhome and how big a job is it?
I was quoted almost 8 grand by an RV body shop!Beyond my budget!
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 02/24/12 04:32pm Link  |  Print  |  Notify Moderator
I can't help you LJ on the other side of the country from you! But, $8,000.00 is way to much for some sanding and reclearcoating IMHO!
hershey
Albuquerque,(fulltime) NM, USA
Posted: 02/24/12 04:48pm Link  |  Print  |  Notify Moderator
Totally unreasonable.
A friend of mine has the same problem and we tried the Red Max treatment [emoticon]
It didn't work. The edges of the problem area doesn't have the same color so the coating didn't clear that edge up. The area where the clearcoat was gone completely did indeed shine real well.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
MountainAir05
New Mexico
Posted: 02/24/12 05:09pm Link  |  Print  |  Notify Moderator
Is this a clearcoat/basecoat or a clear paint on top of a gel coat. Clear coat needs a basecoat to melt into. A clear paint is just a coating over a paint. To answer your question I am in the process or sanding off and re-doing. I have just over $500 in paint so far, Got about 1/4 done. Had to delay untill it warms up again. Good luck. Check in with your local paint store. Your cost is the same as I got local here.
Randy A
Central PA
Posted: 02/24/12 05:10pm Link  |  Print  |  Notify Moderator
You should have a good knowledge and tools for doing body work, especially on fiberglass. If you do it won't be that big a job.
John & Angela
World Travelers.
Posted: 02/24/12 05:21pm Link  |  Print  |  Notify Moderator
This is common on Motorhomes of almost every make. We have a fellow in the park here who makes a living out of repainting and clearcoating just the front and rear caps. Aproximately 1800 for front and back.
Ours did the same thing. If you have the time and about 100 bucks you can do it your self.
Sand and prep
Basecoat once or twice.
4 coats of clearcoat using a 2 part clear. I recomend Spraymax 2K. It is a 2 part clear coat that comes in a special can that once punctured must be used in 48 hours. It is a special can with special nozel. About 22 bucks a can. Professional results. You will need two cans for the front cap.
Here is a YOUTUBE link
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
fcooper
St. Augustine, Florida
Posted: 02/24/12 05:31pm Link  |  Print  |  Notify Moderator
One of the regular posters named DEANDEC has posted about his repair. I found one of his posts. Links below.
post 1 clearcoat info
Fred
Fred & Vicki
chastho
arkansas
Posted: 02/24/12 05:48pm Link  |  Print  |  Notify Moderator
I had my front cap repainted in Red Bay, AL for $350. That was from the top of windshield back to the roof and down the sides of windshield to blend in the paint. He also painted the little white rain gutter to match the MH.
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 02/24/12 07:38pm Link  |  Print  |  Notify Moderator
Just had mine repaired. Full sanding of the clear coat, two coats of paint and two coats of clear then a final buffing. Also had some dents taken out of the Jeep hood and then painted. All for 800 bux.
Twomed
FL winters and then somewhere cool
Posted: 02/24/12 09:51pm Link  |  Print  |  Notify Moderator
Try Justices's Body Shop..US19 SpringHill just south of WalMart, west side of road. Drive it down, plenty of room. He gave me a good estimate on some paint. Also does a lot of Corvette glass painting. Good Luck [emoticon] [emoticon]
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
