RV.Net Open Roads Forum: Dinghy Towing: Manually moving Tow Dolly after vehicle unloaded
Search only in Dinghy Towing
 > Manually moving Tow Dolly after vehicle unloaded
KenR
Biloxi MS
Posted: 02/24/12 04:02pm Link  |  Print  |  Notify Moderator
I do not own nor have I ever towed with a Dolly and was wondering how hard it is for a 74 year old man to manually move the empty tow dolly to it's campground resting place when unhooked from the Motor Home. I am concerned about the dolly being on grass (no pavement) or having to move it uphill. Is it easy for one person to roll. When stored outside between uses do you cover the dolly with a tarp or what.
Thanking you in advance.
Ken
1997 Winnebago 32 ft Adventurer Ford 460
No longer own the rig below
2003 Dodge 3500 QC SB SRW 2/4 HO with new 48RE with 4.10 rear axle-Reese 16k Kwik Slider towing
2001 31BWFS SunnyBrook 5th wheel-Leland Extended Pin P/N AF 7920, no bedroom slide
sch911
Rochester Hills, MI
Posted: 02/24/12 04:06pm Link  |  Print  |  Notify Moderator
I can move ours by myself, but it's pretty good grunt. I keep it under the back end of the MH in the campsite. Many CG's won't let you keep it on the grass.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
ronfisherman
SE Michigan
Posted: 02/24/12 04:26pm Link  |  Print  |  Notify Moderator
My dolly moves fairly easy. I have a trailer hitch on back of car to move dolly when I cannot move it myself.
2012 Chevy Captiva Toad
Super C Group Forum
lawdash
NY
I find moving the dolly around on uneven or soft surfaces to be a pain, literally. My neck and shoulder always hurt for a couple of days afterwards. To try to help with that, I just ordered but haven't yet received this trailer dolly. I hope it helps!
Our next toad will be 4-down towable.
davelinde
Lake Nona, Florida
Posted: 02/24/12 04:36pm Link  |  Print  |  Notify Moderator
U-haul rents them. You could go ask if you could push one around their lot for free and see. I generally find it pretty easy, but you are right to expect some exertion on grades. I have not found grass difficult, but gravel can be a bit hard to navigate. We only use ours for moving the car between our winter and summer locations.
Oh yes, one other thing to expect - you need to get on the ground under the car to connect/disconnect the safety chains.
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB HO-CTD/48RE
01 Volvo VNL660 singled VED12
09 Heartland Cyclone 3210
Yaj
The Milky Way Galaxy (Fort Myers, FL)
Posted: 02/24/12 04:37pm Link  |  Print  |  Notify Moderator
What if you pull in somewhere and can't turn around? I've had to unhook, move toad, move dollie, move motorhome, use toad to move dollie to motorhome, reload toad. A real pain... only 4down for me.
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser, 2 bikes,
1 DW, 2 kids.
I wasn't thinking this far ahead!
1995brave
San Antonio, TX
Posted: 02/24/12 05:24pm Link  |  Print  |  Notify Moderator
Check out this thread, he was asking how to add a wheel to move the dolly.
KenR
Biloxi MS
Posted: 02/24/12 05:42pm Link  |  Print  |  Notify Moderator
Wow, so fast, with good responds. Sounds like at the moment, wife will drive car on short trips and rent for longer one. I do not want to trade cars (2010 Civic Auto). Renting may be cheaper than trading since so many negatives on Dolly. Thanks again.
jk31668
so. Fla.
Posted: 02/24/12 06:05pm Link  |  Print  |  Notify Moderator
my dolly weighs in at approx. 400 lbs and i have the fold up 3rd wheel on the front which makes a world of difference but even so, on grass or soft dirt it can be a workout. try asking for some help if you cant manage it
lanerd
Ridgecrest CA for the winter
Posted: 02/24/12 06:32pm Link  |  Print  |  Notify Moderator
According to Remco Towing, your Civic is 4-down towable. Why not fix it up for a toad?
Hope this helps
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
