RV.Net Open Roads Forum: General RVing Issues: Gray water tank
 > Gray water tank
Komfort 23TS
Western Michigan
Posted: 02/24/12 05:19pm Link  |  Print  |  Notify Moderator
Why not put black water cleaning chemical in the gray water tank to clean it? I am thinking of all the grease that might be in it. Like Thetfords Campa-clean " waste digestion and tank cleaning". Thank you for your advice
Ka Ron
Kelowna
Posted: 02/24/12 05:21pm Link  |  Print  |  Notify Moderator
I do that with our grey tank once in awhile.
Helps to keep it clean
Join Us For A Trip Down The RV Highway
gbopp
The Keystone State
Posted: 02/24/12 05:36pm Link  |  Print  |  Notify Moderator
Did you ever try the Geo Method?
skipnchar
Topeka or somewhere else
Posted: 02/24/12 08:04pm Link  |  Print  |  Notify Moderator
It's probably a good idea if your gray water tank also serves as a galley tank. If you have a separate galley tank then I don't see any advantage to using it in the gray but the galley could still use a dose once in a while. Best though to try to avoid letting grease get INTO the waste system if at all possible. We put our grease in containers and it goes into the trash dumpster.
ScottG
Bothell Wa.
Posted: 02/24/12 07:34pm Link  |  Print  |  Notify Moderator
I dumped a whole container of Oxi-Clean in my kitchen grey tank. I did it twice and the tank was so clean that even the gauge started working.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
K3WE
Missouri
Posted: 02/24/12 07:51pm Link  |  Print  |  Notify Moderator
Yeah, I don't think caring for the gray tank is forbidden, but in general, the black tank is a bit tougher and doesn't get a lot of soap sent to it during normal operation.
Finally Fulltiming
Summer: NYS Finger Lakes; Winter: Someplace warm
Posted: 02/24/12 10:14pm Link  |  Print  |  Notify Moderator
IMHO, no need for chemicals in gray tank as long as you're semi-careful about what goes in there. I keep a sink strainer in the drain to avoid large pieces of food or whatever from going in & I avoid putting grease down it.
Also dump it at least once/week, sometimes more often depending on parking situation. If you don't let everything sit in there for a long time, you shouldn't have a problem, either with odors or stuff settling in the bottom.
No comparison with the black tank.
Old-Biscuit
Verde Valley
Posted: 02/24/12 11:01pm Link  |  Print  |  Notify Moderator
The tanks are the same......same material etc. so they don't care.
You can use same cleaners, deodorizers, digesters.........or nothing at all and just give them a good rinsing.
badboy368
OHIO
Posted: 02/25/12 04:49pm Link  |  Print  |  Notify Moderator
i treat both my tanks the same. whatever i put in the black tank i put in the grey also. keeps everything squeaky clean. and smellin good too.[emoticon]
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
Ron3rd
Upland, CA USA
Posted: 02/25/12 05:19pm Link  |  Print  |  Notify Moderator
No problem doing that, some do.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
 > Gray water tank
