Komfort 23TS
Western Michigan
Why not put black water cleaning chemical in the gray water tank to clean it? I am thinking of all the grease that might be in it. Like Thetfords Campa-clean " waste digestion and tank cleaning". Thank you for your advice
Ka Ron
Kelowna
I do that with our grey tank once in awhile.
Helps to keep it clean
Join Us For A Trip Down The RV Highway
gbopp
The Keystone State
Did you ever try the Geo Method?
skipnchar
Topeka or somewhere else
It's probably a good idea if your gray water tank also serves as a galley tank. If you have a separate galley tank then I don't see any advantage to using it in the gray but the galley could still use a dose once in a while. Best though to try to avoid letting grease get INTO the waste system if at all possible. We put our grease in containers and it goes into the trash dumpster.
ScottG
Bothell Wa.
I dumped a whole container of Oxi-Clean in my kitchen grey tank. I did it twice and the tank was so clean that even the gauge started working.
Scott, Grace and Wesly
H0NDA eu2000i
K3WE
Missouri
Yeah, I don't think caring for the gray tank is forbidden, but in general, the black tank is a bit tougher and doesn't get a lot of soap sent to it during normal operation.
Finally Fulltiming
Summer: NYS Finger Lakes; Winter: Someplace warm
IMHO, no need for chemicals in gray tank as long as you're semi-careful about what goes in there. I keep a sink strainer in the drain to avoid large pieces of food or whatever from going in & I avoid putting grease down it.
Also dump it at least once/week, sometimes more often depending on parking situation. If you don't let everything sit in there for a long time, you shouldn't have a problem, either with odors or stuff settling in the bottom.
No comparison with the black tank.
Old-Biscuit
Across the USA
The tanks are the same......same material etc. so they don't care.
You can use same cleaners, deodorizers, digesters.........or nothing at all and just give them a good rinsing.
badboy368
OHIO
i treat both my tanks the same. whatever i put in the black tank i put in the grey also. keeps everything squeaky clean. and smellin good too.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
Ron3rd
Upland, CA USA
Komfort 23TS wrote: Why not put black water cleaning chemical in the gray water tank to clean it? I am thinking of all the grease that might be in it. Like Thetfords Campa-clean " waste digestion and tank cleaning". Thank you for your advice
No problem doing that, some do.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
