cjtclinedinst
Hagerstown, Md.
I have a Dometic refrigerator Model NDR 1292. It has stopped cooling. Any suggestions on how I can determine the problem? Thanks
Its not cooling on gas or electric
edited 02/24/12 07:39pm by cjtclinedinst *
06 4301MADP
04 Odyssey toad
Alpenliter
Fulltimer: Wherever we are!
Jim, you didn't mention if it is not cooling on both electric and gas. More information needed.
Trouble shooting tips might help you out.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
Johno02
Lexington, TN USA
Open the outside cover and see if there is any yellow stuff showing.
Noel and Betty Johnson
2005 GulfStream Ultra Supreme, 1 wife, 1 Poodle
John3872
Iowa
Do you have ammonia smell inside the fridge?
2003 Chevy 2500HD Duramax Crew Cab
2009 Palomino Sabre 30RLDS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
2ndhom
Eugene, Oregon
Still need more info ... any error lights on the door? Is light on inside the fridge? Did it stop cooling all of a sudden? Has breaker been tripped? Power needs to be going to fridge whether on gas or elec.
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Alpenliter wrote: Jim, you didn't mention if it is not cooling on both electric and gas. More information needed.
Trouble shooting tips might help you out. X-2, need more info!
othertonka
Stockton, CA
Is your "House" Battery fully charged and the disconnect switch in the ON position? You need a good 12 volt supply for the refer board to operate on propans or 120 V AC electric.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Old-Biscuit
Across the USA
cjtclinedinst wrote: I have a Dometic refrigerator Model NDR 1292. It has stopped cooling. Any suggestions on how I can determine the problem? Thanks
FUSES
This model is equipped with 2 fuses, one for the refrigerator
control system and one for AC cartridge heater.
To replace fuses proceed as follows.
1. Disconnect the wall plug, and the 12 volt wires.
2. Remove the power module cover.
3. Snap the fuse out of the fuse holder.
4. Fit a new fuse in to the fuse holder.
5. Replace the power module cover.
Control system 3 Amp
AC heater 5 Amp
pigman1
Delaware
I had the same problem a while back. After changing just about everything on the fridge without any permanent resolution (including 2 Amish cooling units), I put a Kitchen Aid 2 door household refrigerator in and couldn't be more pleased. NO ONE really understands the problems these 12 cu ft units experience, and they therefore cannot fix them. Do what you have to do, but problems like this can be a real money pit. Just be aware. There are not too many new coaches using these units any longer, with good reason.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
eadeal55
Suffolk VA
Have same fridge, and it stopped cooling early last year. After checking the power and fuses, I opened the outside access and to the left was a yellow spot. Coolant leak. Took MH to my RV service guy and he confirmed the cooling coil was leaking. He ordered a new coil from RV COOL (RVCOOL.com), which is where my service contract company directed him to go, and everything was back like new in about 6 weeks. Rebuilt cooling unit was about $850, labor was about $500, and I paid the $200 deductible.
Andy & Lee, plus Ruby & Bella, the Cocker Spaniel girls
'05 Fleetwood Bounder 33R, F53 w/6.8L V10...towing a
'07 Chevy HHR LT2 w/2.4L EcoTec,
Blue Ox Aventa LX, Brake Buddy Classic
FMCA #F359977 - Colonial Virginians
FCRV #733452 - Tidewater Wheels
