Just picked up my new Voltage 3600 Epic today! Great!
Anyway, I said on another thread that I would post the weights I got on it.
On CAT Scale, it weighed 14,860 pounds. It had option of the Generator, which must add 3-400#, mostly on the pin. The Air Ride pin must add 100# or so too. The propane tanks were filled, which add another 60# to the dry weight.
Total of about 400# above dry weight added to the pin? My best guess.
Pin wt. was 3140#, less the approx. 400# with those above items added, nets pin wt. of 2740, which is the listed pin wt. in the literature.
So, the specs are pretty close.
Cannot wait to take it out. A couple snow storms lined up here in ND now, so will have to wait a bit!
14,860# dry weight as in right off the dealers lot? And pin weight of 3140#....
After you get it loaded up.....be interesting to see the ready to camp/toys weights.
What were your truck weights?
It's been a fairly mild winter....maybe spring will come early....or at least thaw out enough for a shake down trip. Enjoy!
MadMav wrote: That's a light pin. Hope you don't have alot of heavy toys that will lower it.
Mav
I have seen figures for 5th wheels for pin wts. to be between 20 and 25%. This works out to be 21.1%, within that range.
And remember, there is NOTHING in the trailer. No water, nothing in the front bedroom, no kitchen supplies. I have no doubt that it will go up as I add stuff to the front of the trailer.
It also has one group 24 battery. I have 3 group 27 batteries to go in the front compartment, so that will add close to a couple hundred pounds right there!
When I put my Valkyrie with sidecar in my previous toyhauler, which was a twin axle, about the same length, it took about 150# off the pin. I will be adding more than that. The batteries alone will make up that difference.
Old-Biscuit wrote: 14,860# dry weight as in right off the dealers lot? And pin weight of 3140#....
Interesting that the steer lost 220# with the trailer hooked up. I wish it had added a little.
When I weigh the trailer loaded later on, I am going to recheck that difference.
2004 dodge dually
MP
I'm real surprised that you lost that much weight off front axle.....
Real good idea about the re-weigh when camp ready......watch the rear tire loading, you may be pushing max depending on how that trailer is loaded.
We get weighed every year....just to stay informed. Cheap, easy to do and helps stay within limits.
Enjoy!
Mav
I think I am OK.
MP
It's the loaded weight that counts. IF you have toys/water, more than likely that weight will drop. Interested to see what it is when loaded with toy and all. I would hope that the pin is above 18% for handling. Below that could cause problems. I have experienced this.
2004 dodge dually
MP
Enjoy!
Not too concerned about overloading the tires. @60#, each carries 2600#. That is 10,400#. Since I am now at 6320#, I could add 4,080# to the pin weight. LOL
I wouldn't sweat losing a few lb's off the front axle. You have WAY more capacity on the rear axle as these Dodges are a little light in front axle rating (5200lb) due to the wheels only being rated at 2600lb. Driver, front passenger, and some more weight like firewood, and maybe some rear passengers in front of the rear axle and you will be real close to max front axle weight.
I moved my hitch 4" back to lighten the front axle due to being over 500+lb. By a calculator I used online, 4" back only moved my 3K pin weight 120# front to back. People place way too much emphasis on that 1" in front of the axle......It really doesn't make a huge difference, especially on a long bed.
Now my wheels are rated to 7300# ea. and I have a winch/bumper combo. Wonder what the real rating is on the front axle? Not just the weakest link....the wheels....
mpierce wrote: Just picked up my new Voltage 3600 Epic today! Great!
MP
With the pin weight so light on the 3600's whats the opinion on towing one with a new SRW F350? I love this trailer :-)
