RV.Net Open Roads Forum: Tech Issues: Q Industries MV50 SuperFlow High-Volume Air Compressor
 > Q Industries MV50 SuperFlow High-Volume Air Compressor
LostinAZ
At Home
Posted: 02/24/12 10:03pm Link  |  Print  |  Notify Moderator
Anyone using this air compressor? If so I would appreciate knowing what your experience has been. TIA.
2oldman
Winchester WA
Posted: 02/24/12 10:18pm Link  |  Print  |  Notify Moderator
Mv50 posts
ronfisherman
SE Michigan
Posted: 02/25/12 04:43am Link  |  Print  |  Notify Moderator
I use one with good success. Modified the outlet quick connect to accept a standard air quick connect after I made sure compressor worked.
Kodiak Chassis Class C Forum
WyoTraveler
Northwest, Wyoming
Posted: 02/25/12 08:28am Link  |  Print  |  Notify Moderator
I have been shopping for a air compressor like this. What did it take to modify the MV1050 for a standard air quick connect fitting? Did you just run a 1/4 inch NPT tap into the hole? I understand the threads are different and not standard.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
ronfisherman
SE Michigan
Posted: 02/25/12 09:25am Link  |  Print  |  Notify Moderator
I tapped out the hole with a 1/4" pipe tap. No drilling needed. Be sure to clean all the chips out after tapping.
smkettner
Posted: 02/25/12 02:56pm Link  |  Print  |  Notify Moderator
MV-50 has worked excellent for me for about 5 years.
I don't use it that much but it will certainly get a tire to 65psi without breaking a sweat.
675 watts solar
Wanderman
New York
Posted: 02/25/12 03:03pm Link  |  Print  |  Notify Moderator
I replaced a wheezing Hadley air pump (for my airbag system) with one of these. Simply tapped the weird sized inlet and outlet then connected standard fittings. It's mounted permanently where the old one was.
Works VERY well.
Rich "The Wanderman"
1991 Aero Cruiser 23RBa
Read All about my Disasters and Triumphs at:
http://www.thewanderman.com/
OldGreaser
South Texas
Posted: 02/26/12 09:05am Link  |  Print  |  Notify Moderator
Mine works okay but is very hard on fuses once it is hot. I leave it running in between connecting to tires. If I shut it off before hooking onto the next tire and then start it up most of the time the fuse blows. Otherwise it's meeting my needs.
RV daytrader
PA
Posted: 02/26/12 11:06am Link  |  Print  |  Notify Moderator
shoot!...amazon just had it on sale for 49.95, free shipping...back up tp $79 now!!
YODA...our lil Toyota!
1989 Toyota Seabreeze
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 02/26/12 11:40am Link  |  Print  |  Notify Moderator
Amazon has these listed under several different names. Keep checking as they have them for reduced prices all the time.
Other listed name Master Flow MF-1050
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
