KD4UPL
Swoope, VA
If your transfer switch is installed correctly there is no reason to disconnect form shore power.
My transfer switch automatically switches to the generator when it is running. It's a simple matter of hitting the generator start button. That's it.
jdair101
ontario
is it normal to hook up the genny as the primary power sourse in a transfer switch? I just hooked up one in my TT and used shore power as primary and inverter as secondary.
joebedford
Jasper, Ontario
cewing wrote: I am new to having a generator on board so this ? may sound funny. If hooked up to shore power and want to run the gen. for monthly test or run should I dis-connect shore so it will not back feed thru shore cord? Or when gen. is running does it auto switch from shore to gen.?
I have a 2012 Voltage 3950
My Voltage 3950 (alas "only" a 2011) is connected to a 15A GFCI when it's at home. Starting the generator without unplugging trips the GFCI every time. Maybe if I was connected to my 30A non-GFCI, it wouldn't trip the breaker, but why take a chance on damaging something. I'm guessing that before the transfer switch does it's thing, some kind of transient is going back up the shore power cord - not good!
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
KD4UPL
Swoope, VA
When plugged into shore power your neutral and ground need to be separate. When running on a built in generator they need to be connected. Your transfer switch is doing it's job properly and connecting them when powering the trailer from the generator.
The problem is that a neutral to ground fault will trip a GFCI outlet. If you were plugged into a standard 30 amp RV outlet with no GFCI protection nothing would trip.
Your setup is working correctly.
CrazyTed
Hoollieville #214
In my experience, I have seen two different RV's destroy their transfer switches by starting the generator while on shore power. One basically blew the plastic off the side of the transfer switch. Mine was a 5ver that luckily they replaced the switch under warranty. My father has a Forest River DP where the generator was having difficulties one day so he hooked it up to shore power while he worked on the generator. On the third time he started the generator, the shore power switch swapped back and fourth continually for about fifteen seconds and then stopped working. Had to replace it. In my opinion, the cord is easy enough to unplug so why take a chance?
CrazyTed
www.CrazyTed.us
Va Bch, VA
2010 Husaberg FX450
2008 Triumph Rocket III
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS (Sold)
2009 Jayco Seneca HD 36MS
jauguston
Bellingham, WA
Normally default is generator.
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
lanerd
Newport, OR
People, you really need to look at your owner's manual and do exactly what it says. In my case, it specifically states that the GENERATOR has priority and that the transfer switch will automatically switch over to the generator whenever it is running regardless of anything else supplying power.
Obviously not all rv's are built the same....getting advice from here on this type of subject is just asking for trouble if you follow it without question. Your owner's manual is your bible. If you doubt your manual, then contact the manufacture....
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
mpierce
Scranton, ND
Just got a voltage 3600, and went to check on this. It has a list of things to do before starting the generator. The last one on the list is to "connect the shore power cord to the shore power recepticle".
Of course, if you were boondocking, that would not be possible.
So, it does not sound like having it connected to shore power is a problem, in fact, they tell you TO CONNECT IT.
Onan 5500 generator
MP
BobWanderer
Perris,Calif,USA
KD4UPL wrote: I have a 2012 Voltage 3950
The problem is that a neutral to ground fault will trip a GFCI outlet. If you were plugged into a standard 30 amp RV outlet with no GFCI protection nothing would trip. Your setup is working correctly.
So, is that why my voltage/frequency monitor Ground Fault light is on when running the genny ??
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
