BR_Bo
Las Vegas, NV
I'm new to 5'vers. What do you think? It looks like a little squat, but the camper looks fairly level. Am I going to have a nose-up condition if I add some airbags? If I do add the bags, do you think I'll notice much difference in the ride?
Thanks!
donn0128
Pronounced Ore-gun
Get to the scales!
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
45Ricochet
North Idaho
Looks perfect to me
You should have a nice big pin weight, makes for a nice riding truck. Mine squats about 3-4" hitched up.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
larry barnhart
wenatchee. wa usa
the truck is high on the front. Easy to see this so add the airbags for a level drive. Nice outfit.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Texas Jim S
Belton, TX
Rich, it will raise the rear of your truck, get your headlights out of the oncoming drivers eyes, and improve the ride BUT then your trailer will be too close to the bed of your truck. It may be dificult and or expensive to raise your trailer enough for it to stay level. There may already be holes in the frame of your trailer that will inable you to relocate the spring hangers to that may level it. You can also raise it with larger tires OR by relocating the axle under the springs.
wcjeep
Tacoma, Wa
Check out the Torklift stable load. Might be Perfect for your application.
CREATO
Beautiful Harvey N.D.
air bags dont affect ride I would put them on
I dont rent out space in my brain
Oasisbob
Portland Oregon 97266
Front appears to be up a bit. Yes, I would go with air bags. Is your trailer loaded and ready to go in these pics? Air bags let you stiffen for towing and relax when not. Looks a tad tail heavy to me. Nice rig.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
lawnspecialties
Garner, NC
Ditto on the air bags. Heck, I put them on my F450 a week after I bought the thing.
2011 Ford F450 4X4
2011 Cyclone 370C
BR_Bo
Las Vegas, NV
The camper is empty in this pic - took it right after driving home from the dealer. Also going to put a 63 gallon fuel tank in the bed, so that will add additional weight as well. It looks like the spring hangers are in the top hole already.
I'll probably add the airbags and see how the clearance looks.
