RV.Net Open Roads Forum: Truck Campers: In need of some Yakima space
 > In need of some Yakima space
James'
Ventura, CA
Posted: 02/25/12 03:59pm Link  |  Print  |  Notify Moderator
Need a little input...
Adding this Yakima to the TC and found the only area that it can really go is here. I'll need to secure it to the roof via a home made rack. I was wondering if taping into the roof is a good idea? Any thoughts?
* This post was edited 02/25/12 09:31pm by an administrator/moderator *
2006 Chevrolet 3500 HD 4X4 dually, crew cab.
6.6 diesel, Allison trans. Air bags.
2011 Lance 992 duel pop-out, 2200 gen, 135 watt solar panal, Yakima skybox.
Executive
Posted: 02/25/12 04:40pm Link  |  Print  |  Notify Moderator
Geeze...are your pix big enough.[emoticon][emoticon][emoticon]...[emoticon][emoticon][emoticon].....[emoticon][emoticon][emoticon]....Dennis
Run a few ratchet ties around the whole thing and you're good.....D
THE PROBLEM WITH OPINIONS IS EVEN IDIOTS ARE ALLOWED TO HAVE THEM
Dennis and Debi Seventh Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
kerry4951
East Central Pennsylvania
Posted: 02/25/12 05:03pm Link  |  Print  |  Notify Moderator
Satellite dishes, roof racks, TV antennas, solar panels, etc, are fastened into the roof. Like anything else, use the proper sealants and you should have no issues. I would rather have a professional looking installation even if it means drilling and screwing into the roof. Keep and eye on the sealants/caulk periodicly and you should be good to go.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
GregTheCampingGuy
Morgan Hill, CA
Posted: 02/25/12 05:50pm Link  |  Print  |  Notify Moderator
Shame you don't have a Thule storage pod then you could use the racks as intended. Just curious, how much did you pay for the solar?
old guy
Oregon (pronounced Or e gun)
Posted: 02/25/12 06:31pm Link  |  Print  |  Notify Moderator
don't let them get to you about the pictures being big. I can at least see what you are talking about now.
James'
Ventura, CA
Posted: 02/25/12 06:33pm Link  |  Print  |  Notify Moderator
The solar was $350.00 for 135 watts. They have come down in price:
Wind & Sun
* This post was edited 02/25/12 06:58pm by James' *
James'
Ventura, CA
I set them to 640x480 oh well. [emoticon]
I guess what I'm concerned about is making sure that whatever I'm screwing into will hold. Do you think these things have 3/4" plywood up top? it feels like it.
Buzzcut1
Norcal
Posted: 02/25/12 07:20pm Link  |  Print  |  Notify Moderator
Just cover the roof and the bottom of the box with industrial strength Velcro[emoticon]
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 02/25/12 10:00pm Link  |  Print  |  Notify Moderator
Executive wrote: "Run a few ratchet ties around the whole thing and you're good....."
Wouldn't something like this be a better idea than attaching the box permenantly?
Paul
SoCalDesertRider
Arizona desert
Posted: 02/26/12 04:55am Link  |  Print  |  Notify Moderator
If you build 2 cross members that span the width of the camper, you can mount the cross members to the top edges of the outer wall framing, then mount the box to the cross members. This is how most truck camper roof racks are mounted. The walls have the strength. The roof deck surface, if not mounting into the roof joists beneath, is not so strong as the walls are, for carrying much weight.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
© 2016 CWI, Inc. © 2016 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
