RV.Net Open Roads Forum: Dinghy Towing: ReadyBrute towbar with ReadyBrake
Search only in Dinghy Towing
 > ReadyBrute towbar with ReadyBrake
docj
Fulltime--Home is where we park it
Posted: 02/26/12 01:09pm Link  |  Print  |  Notify Moderator
MSHappyCampers wrote:
I've got a question. If you are using an exhaust brake on the MH and the Ready Brake or any other brand that operates by pressure from the toad against the MH, it seems that the toad brakes will be applied when the exhaust brake activates. Any thoughts on this!
When my Jake brake is slowing the coach down, the ReadyBrake can activate if the deceleration rate is high enough. But it is a proportional braking system so the degree to which it activates is governed by how fast you are slowing down. If I'm coming down a mountain the ReadyBrake is not on if I am maintaining a particular speed; it engages when I slow down.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
MSHappyCampers
Columbus, MS
Posted: 02/27/12 02:03pm Link  |  Print  |  Notify Moderator
I talked to a guy at Ready Brake company today and he told me that the Ready Brake should never activate when the exhaust brake is used. He said that if it does then the cable to the toad brake pedal is probably too tight. You might want to give them a call.
Joe & Annette
2002 Monaco Windsor 40PBT
