MSHappyCampers wrote: I've got a question. If you are using an exhaust brake on the MH and the Ready Brake or any other brand that operates by pressure from the toad against the MH, it seems that the toad brakes will be applied when the exhaust brake activates. Any thoughts on this!
When my Jake brake is slowing the coach down, the ReadyBrake can activate if the deceleration rate is high enough. But it is a proportional braking system so the degree to which it activates is governed by how fast you are slowing down. If I'm coming down a mountain the ReadyBrake is not on if I am maintaining a particular speed; it engages when I slow down.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
I talked to a guy at Ready Brake company today and he told me that the Ready Brake should never activate when the exhaust brake is used. He said that if it does then the cable to the toad brake pedal is probably too tight. You might want to give them a call.
