RV.Net Open Roads Forum: Fifth-Wheels: What is the Best Strong Arm Position
 > What is the Best Strong Arm Position
Jim4929
Roanoke, VA
Posted: 02/25/12 06:02pm Link  |  Print  |  Notify Moderator
My fiver is scheduled for delivery Friday and it will have Strong Arm stablizers installed on it. Different dealers show them installed differently. Some are installed at the bottom of the legs, while others are installed half way up or higher. What position provide the most stablility?
* This post was edited 02/25/12 06:12pm by Jim4929 *
2011 GMC 3500 Sierra Diesel SRW
B&W Patriot Hitch
5th Airborne Pin Box
Laredo 321BH
"Have Trailer, Will Travel"
Scooter Alfa
Central Cal
Posted: 02/25/12 06:37pm Link  |  Print  |  Notify Moderator
Bottom of the legs to the frame. http://www.jtrv.com/images/products/jack_stabilizer/5thWheel_instructs.pdf
Robin1953
Ashton, WV
Posted: 02/25/12 06:49pm Link  |  Print  |  Notify Moderator
Clicky
Robin Brumfield
2011 Dodge 3500 DRW CC
2012 Jayco Eagle SuperLite 31.5RLTS
fj12ryder
Platte City, MO
Posted: 02/25/12 07:07pm Link  |  Print  |  Notify Moderator
I'm a bit confused about how you would mount them anywhere other than to the bottom. I've not seen all iterations of front stabilizers legs, but all I've seen telescope into the leg housing. If the Strong Arms were mounted anywhere but at the bottom you wouldn't be able to telescope the stabilizer legs into the housing very far.
At least that's the way I see it. Also the longer the hypotenuse of the right triangle is the stronger it will be. Up to a point of course. And yes, mine are mounted to the bottom of the stabilizer legs.
Howard and Peggy
"Don't Panic"
tvman44
Southwest Louisiana
Posted: 02/25/12 07:30pm Link  |  Print  |  Notify Moderator
Anywhere but the bottom of the legs will not do any good.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
BB_TX
McKinney, Texas
Posted: 02/25/12 08:01pm Link  |  Print  |  Notify Moderator
Instructions that came with mine said bottom, with the bolt thru the pads brackets. I am surprised there is any other way to do it. Any higher up and my jacks could not raise all the way.
57 Panhead
Central Valley Calif.
Posted: 02/26/12 09:26am Link  |  Print  |  Notify Moderator
If you haven't already committed to the Strong Arm product, I would suggest you take a look at the Steadyfast system, easier setup, only 3 points to tighten and they keep our unit rock solid. About the same cost as JT and easier to install as well.
Check them out here:Steadyfast Stabilizers
Disclaimer: I have nothing to do with Steadyfast company, I just use and like their product.
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
ljr
Pennsylvania
Posted: 02/26/12 06:18am Link  |  Print  |  Notify Moderator
Mine were factory installed connected to the bottom. Frankly, I don't see (feel) where locking them makes any difference.
Larry
Jim4929
Roanoke, VA
Posted: 02/26/12 06:29am Link  |  Print  |  Notify Moderator
I thought the bottom would be the best since the steady fast system I had was at the bottom but I saw more than one picture mounted like this and I didn't know if some else knew something I didn't.http://www.holmanrv.com/inventory/189772/New-2012-Keystone-RV-Laredo-321BH.aspx
larry barnhart
wenatchee. wa usa
Posted: 02/26/12 08:01am Link  |  Print  |  Notify Moderator
We can see this odd way isn't using a though bolt so a special clamp is used. kinda feel the new owners of JT are doing their cheaper method of manufacturing.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
