07blacktruck
BAF Afghanistan
Wow, that is awesome. I've been lurking on this forum for awhile and have to say I had not heard or seen a word about that brand of camper. I had not considered the pop up campers at all but I do like that one. I didn't see a weight but it did show it on a 3/4T truck. Might have to look into one of those campers. I would have to get over the lack of solid wall thing but that might be doable. The rear fold out would be good for guests if any ever came along. All that and I could pull the scooter or ATV with no problem with something like that unit.
Thanks for the link. It didn't link on my computer but a little cut and paste and I was in. Good to go.
Thanks.
The inherent vice of capitalism is the unequal sharing of blessings;
the inherent virtue of socialism is the equal sharing of miseries. Winston Churchill
NorthernLimits
Michigan
Side door is so much easier to get in and out of when it's on the truck. Especially when hauling a trailer.
07blacktruck
BAF Afghanistan
Pretty much what I have been thinking. I wonder how the soft sides on the Outfitter models would be for insulation. I could see me heading off to do some winter camping and I would hate to find out they aren't so good for that. I do like the side door for sure. I wouldn't plan on pulling a wagon for every trip but most of them particularly when the weather was good.
2BLAZERS
KEIZER, OREGON
We have a back door in our AF 1150. We keep the trailer(s) hooked up the entire time when camping, We have two flip down steps that are to the right side of the camper so we can leave them down and the trailer hooked up all the time. Never been an issue for us. If AF ever makes a side door model we might look but that would be the only reason we would do it.
2011 Dodge Ram 3500 4*4 Black dually Laramie 4.10 gears
2011 Arctic Fox 1150 Drybath
2009 Polaris RZR w/fun parts
2011 Polaris Sportsman 550 XP EPS w/stuff
2006 Polaris Sportsman 500 w/stuff
1977 K5 Blazer 1 ton modified
2007 Toyota Camry Hybrid (her car)
fast.5
Ontario, Canada
Hi. We have had a couple of rear entry and have had two side entry
They are both good in there own way. The rear entry allows for longer
Things to go in the camper like a canoe. As long as you can swing the trailer
A bit to one side then it is not in the way. Some camp sites are better for the rear
If you are unloading and the slope of the land is in the
wrong direction. With
A side entry it can put your door on the wrong side. The rear entry will collect road
Grime and can be nasty the side door not so much. I would
Be more concerned with the layout that you like over door position
I have towed a bass boat and atv trailer with both and it never bothered me.
You have the right truck to get what you like and still tow a trailer up to 5000
Pounds. That all said we like the side entry and the layout we have to do
What we do in the way of camping.
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
SoCalDesertRider
SanDiego, CA, USA
Both of my rear-door campers had the doors offset to one side. I never had a problem with accessing the campers while towing. If the door was dead center, I could see that being not so great with the trailer hooked up.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
BobTowne
Fairfield, CA, USA
IMHO the issue is useable space in a truck camper where space may be at a premium, anyway. A side entry camper would be my preference in theory; however, in practice all of the side entry camper I've seen have alot of dead space precisely because of the side entry. In the end it's your decision, and obviously others don't feel the same way...
GreatWhite
2004 Dodge Ram 3500 Quadcab Dually
2004 Alpenlite Santa Fe 1150
bphusmc
michigan
I have had both, a shadow cruiser, and a 3000 Bigfoot . To me my present Eagle Cap 1160 with the side entry with the built in steps is much safer to enter and exit. Both do have advantages. Once you have the side entry it will be hard to go back to the rear entry. I have this on a 2012 3500 Chev and it performs well even with a small trailer attached.
Tech Dude
Torrance
Hang bikes with side entry
Atchafalaya_man
Lafayette, Louisiana
I prefer a rear door for THREE reasons.
1) I can see out the lower window of the camper door using my windshield's rear view mirror. I can see traffic tailgating me or know that the boat is still back there. It's totally hidden when towing down the highway. (I know they make rear cameras but I prefer a live look.)
2) We launch and retrieve our boats with the camper loaded. So, we open the rear door and the boat driver and truck drive can see each other and communicate using hand signals. (I know they make radios. We have them too, but seeing someone POINTING which direction they want you to back is easier than hearing "this way" over a radio.) The driver looks back through the back door as if the camper wasn't there.
Most side entry have a solid wall and no ground level windows. Perhaps one up high, but it does nothing for you.
This is especially important when the trailer is directly behind the camper. The driver is 100% BLIND as to how far back the trailer is when nearing a barrier in a parking lot, or the water's edge at a ramp.
Give me a back door, with a lower level glass window, for traveling, towing, and backing.
3) We primarily BACK IN to our camping spots. They usually offer the best view of the lake, etc., directly behind the camper. With a side entry, you see the next door neighbors. We spend a LOT of time with the back door open, overlooking the scenery.
Back Door View...
