RV.Net Open Roads Forum: Class A Motorhomes: Need to replace clearance lamps
 > Need to replace clearance lamps
Rhyph
Georgia
Posted: 02/26/12 05:44am Link  |  Print  |  Notify Moderator
Howdy!
I'm trying to find a source for replacement clearance lamps on the roof of our coach. It is a 1997 American Tradition. The red lamps on the rear have finally deteriorated to the point where the lenses on them are cracking, and they are starting to seep some water into the fixtures. I called Fleetwood and they want some insane $29/each for the red ones on the rear cap, and $17/each for the amber on the front. I couldn't get Fleetwood to tell me who made them.
Has anyone tackled replacing them before, and can tell me what's involved or what to expect when I pull them off? I want to replace them all, but I don't want to touch them to see what wiring is present (are they two-wire or ground via screw), etc as they will most likely fall apart when I do... then there's no return without a suitable replacement at hand.
Does anyone know who made them and is there an aftermarket equivalent replacement? Would love to go LED. I don't want to get into crazy modification, so I would be grateful for any ideas on something that's a close fit, and a source to order them. My google searches return the typical generic stuff, but they don't look very nice, or you can't find matching red for the rear.
They sort of look like Pacer Performance 20-105, but only come in amber, so that won't work for the rear.
Thanks in advance!
2003 Dodge Ram 3500 4x4 CTD QC
1997 American Tradition 38TTF
2007 Honda Accord EX V6 Coupe Toad
patinlouisiana
Baton Rouge, La
Posted: 02/26/12 07:07am Link  |  Print  |  Notify Moderator
You can find them in any busy campground
Just don't get caught.
Seriously though there should be some type of registered "Mark" in the lenses that could be traced to a manufacturer.
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
Executive
Posted: 02/26/12 01:05pm Link  |  Print  |  Notify Moderator
If it were me, I would replace the entire assembly with LED lights. Many mfg use Bargman lamps. Check below to see if you can get a match. I would remove one of the front lamps, since they are the least necessary lamp and get the SAE number off the lens. A google search will let you know the mfg. Then, upgrade....here's the link..look at #37 or #99.....Dennis
Bargman LED
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
MountainAir05
New Mexico
Posted: 02/26/12 09:23am Link  |  Print  |  Notify Moderator
http://www.ryderfleetproducts.com/ryder/
If water is/has gotten, then replace the hold light assy.
FormerBoater
South Florida
Posted: 02/26/12 07:31am Link  |  Print  |  Notify Moderator
Rhyph wrote:
Howdy!
Thanks in advance!
You can get these teardrop clearance light lenses at many truck parts wholesalers. I purchased mine at L&L Distributors in Pompano Beach (954)-979-1200. Just describe them and give them the SAE number that is found on the lens.
Very inexpensive.
Replacement is very easy, take off the old, install the new and apply some silicone around the the lens and fill in silicone on top of the screw.
L&L will sell you the complete light assembly or just the lens. I recommend you just replace the lens and bulbs if necessary.
Dave
1998 American Eagle 40EVS
