RV.Net Open Roads Forum: Towing: Wide track axles - Do they really help?
Search only in Towing
Open Roads Forum  >  Towing
 > Wide track axles - Do they really help?
mrgeezer2u
Reading, PA
Posted: 02/26/12 08:55am Link  |  Print  |  Notify Moderator
eric james wrote:
mrgeezer2u wrote:
eric james wrote:
I think your Tourag will do a good job. Just need to get the right trailer. Power is rarely the issue with most SUVs. It's wheelbase and payload.
Before I got the Expedition, I towed with a V8 Grand Cherokee. 106" wheelbase.
I towed a 26' 4200lb trailer for two years. It was fine. A really good WD Hitch would have been better for me.
I would recommend nothing over "26" in the model number and go ultra light. Get an Equal-i-zer or Reese Strait Line hitch minimum.
How heavy? Take your towing capacity x 80% then subtract 1000 lbs. That number would be the max dry weight to shop.
Thanks. You have confirmed much of what I've read. Only problem is that we like the rear living trailers and many with 27 in the model number. I know that's pushing it which is why I'm asking about the wide axles. Trying to stay around 5,200 lbs dry. Either way, we will use a good WD and sway control hitch.
I don't think 26-27 should be a deal breaker. Your VW's wheelbase is 5" shorter than my Expedition. I towed that pictured trailer with the Expedition effortlessly. Now the Passport is the max I can handle.
How often/far do you plan to travel?
Well, we "plan" on travelling a lot, maybe even cross country. That's why I'm concerned about how it tows. What model Passport? We like the 2850 but afraid a bit too long?
BTW, how are things in Sioux Falls? Haven't been there in years. Used to go there a lot when I worked for Western Surety.
eric james
Sioux Falls, SD
Posted: 02/26/12 09:14am Link  |  Print  |  Notify Moderator
Extensive travel = shorter trailer unfortunately in my opinion.
When I run across the state to the Black Hills with my set up, after 5 hours in the wind, I'm tired.
You'll have to do some digging to find a shorter rear living room floorplan. I looked at the 2850 you mentioned and I wouldn't feel comfortable with that much trailer long travels. Locally maybe.
Sioux Falls is a hidden gem in the snow banks. We moved here in 2001 and the growth is very positive. Stop by on your cross country travels. [emoticon]
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
bfast54
Traverse City ,Mi.
Posted: 02/26/12 09:21am Link  |  Print  |  Notify Moderator
Transporting RVs I have found these "New" wide track units are more stable, in my opinion , than many of the old school types.
Keep in mind I have only towed a few ( hundred ) trailers.............so, you may want to take what I say with a grain of salt.[emoticon]
The high "Cheap" aluminum trailers I found were the worst to tow. Did not track well, and wanted to sway, even with my big truck.....could not imagine some of them behind a passenger vehicle.
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller">
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
Terryallan
Foothills NC
Posted: 02/26/12 12:35pm Link  |  Print  |  Notify Moderator
bicyclemark wrote:
The Wide tracks are also more difficult to work with when leveling the trailer with boards.
Just my 2 cents [emoticon]
Why? but then I use lynx levelers, and I'm thinkin it would be the same
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
SoCalDesertRider
Arizona desert
Posted: 02/26/12 12:38pm Link  |  Print  |  Notify Moderator
By 'wide track axle', do you mean a spread axle tandem, or an axle with a wider width? To me, 'wide track axle' means just that, a wider axle. A spread axle tandem has 2 axles that are further apart from each other than a normal tandem set. Spread tandem and tri axles are common on commercial flat bed semi trailers. The forward axle is there to carry loads that weight the trailer heavily in the middle, rather than up front over the tractor's axles or out back over the trailer's axles.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Terryallan
Foothills NC
Posted: 02/26/12 02:48pm Link  |  Print  |  Notify Moderator
Jayco calles it Wide stance Tracker axles. Others call them Stabil Trax. Just supposed to make it trck better.
One of the real benifits. they run cooler, as they are farther apart, and don't heat each other up.
autorot8
Bend
Posted: 02/26/12 03:57pm Link  |  Print  |  Notify Moderator
bicyclemark wrote:
The Wide tracks are also more difficult to work with when leveling the trailer with boards and good luck if you wish to use a between the wheels chalk.
This is no longer true as you can now get Rotochoks for a wide stance axle TT.
2015 Ram 2500 Laramie Crew Cab 4x4 6.4l Hemi to pull my Prime Time Lacrosse 296BHS
"Overstating the Obvious rarely helps the Oblivious!"
mrgeezer2u
Reading, PA
Posted: 02/27/12 06:46pm Link  |  Print  |  Notify Moderator
APT wrote:
I recommend a high quality shorter TT for traveling a lot as a retired couple. Something like a Lance 2285 or 2385. Well under 5000 pounds dry with under 500 pounds dry hitch weight.
I hear ya, but DW wants roooooooom. Need to compromize. Thinking 26'.
bicyclemark
Saint Paul, MN
Posted: 03/19/12 07:13pm Link  |  Print  |  Notify Moderator
The leveling boards will have to be that much longer. Longer boards take up more room and are a bit more unwieldy. I suppose you use 2 sets.
APT
SE Michigan
Posted: 02/27/12 07:42am Link  |  Print  |  Notify Moderator
2017 Subaru Outback 3.6R
