RV.Net Open Roads Forum: Tow Vehicles: Used F150, help with max payload
Search only in Tow Vehicles
 > Used F150, help with max payload
jerem0621
Sequatchie, TN
Posted: 02/26/12 07:30am Link  |  Print  |  Notify Moderator
How do I know if an 09 and up F150 has the max payload package or not?
I know how to tell at a glance the older models
97-99 the badge says F250 and there are seven lugs
2000-2004 classic the badge says F150 but has seven lugs and says 7700 on the tailgate
2004-2008 all long bed super cabs had the payload package and has 7 lugs
I don't know how to tell about the newer trucks.
Is there a badge that say maxpayload or do I just count the lugs again? 7 lugs?
My next truck will be a used F150 with a payload package.
Thanks
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
RedStickTiger
Spring, Texas
Posted: 02/26/12 07:36am Link  |  Print  |  Notify Moderator
A quick key indicator is the OEM big tow mirrors in the 2011 and 2012's. Good chance it has the max tow.
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/26/12 10:16am Link  |  Print  |  Notify Moderator
Ford used 7-lug wheels on all years of heavy duty payload package F150's (models named F250LD, F150 7700, F150HD, all on the F150 body), from '97-present.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
eric james
Sioux Falls, SD
Posted: 02/26/12 08:59am Link  |  Print  |  Notify Moderator
7 lugs nuts are the instant give away of HD payload.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
donn0128
Pronounced Ore-gun
Posted: 02/26/12 09:04am Link  |  Print  |  Notify Moderator
Look in the glove compartment door. There should be a build sheet there. Check the RPO codes, jot them down and call a Ford dealer. A good service advisor should be able to give you the codes items.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
NewsW
US
Posted: 02/26/12 10:39am Link  |  Print  |  Notify Moderator
What do the certification sticker on the door jamb say?
TURBODOG1000
INDY
Posted: 02/26/12 11:14am Link  |  Print  |  Notify Moderator
X2 the door frame tire sticker should say 8200 lbs max weight.
It can be a standard cab long bed that is the style that SkipnChar had and he was very happy with his.
When I bought our F150 back in 2005 I was forced into the Heavy Payload option because I wanted a long bed extended cab. I have learned to love it! It adds a 1000 lbs to the to the payload but the trucks ride is not as harsh as a F250.
My friends diesel F250 Scab short bed payload is only 90 lbs more than mine but his ride will knock your teeth loose.
I pull a heavy TT approx 8200lbs, I am within all my weight limits and the truck handles the trailer well,(not smooshy). I will admit it is not a bad puller in the ___flatlands___ of Indiana, but we have made 3 trips to Florida over the Smoky Mtns and a couple trips over the Appalachian mtns in PA & NY.
The Heavy Payload Package is a good option, I have been very happy with it, I just wish I had the 7 lug aluminum wheel option back in 2005, painted steel wheels only back then.
* This post was last edited 02/26/12 11:38am by TURBODOG1000 *   View edit history
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
MitchF150
Washington, the State
Posted: 02/26/12 11:44am Link  |  Print  |  Notify Moderator
97-03 are 7 lug wheels and #7700 GVWR
04-current are 7 lug wheels and #8200 GVWR
They do have a 'MAX TOW' option now, but I think that's only with the Eco Boost and will give a little more GVWR on a regular 6 lug wheel rig.
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/26/12 12:18pm Link  |  Print  |  Notify Moderator
Mitch
All true.
The Max Tow option appears to yield a GVWR of 7650 lbs, in some configurations, for current model trucks.
APT
SE Michigan
Posted: 02/26/12 12:44pm Link  |  Print  |  Notify Moderator
7 lug nuts for 2004+. Regular or extended cab 8' beds only.
Confirm with driver's door for 8200 pounds GVWR.
2012 VW Passat TDI
