1995brave
San Antonio, TX
Did you check the fuse panel on the left side of the dash(if it has one)? I think if you open the drivers door you will see a cover and behind it is a fuse panel for the interior items.
ib516
Up here!
Check for the diagram on the backside of the panel cover. Open it up and flip it over. I'm pretty sure there's a diagram there with everything labelled.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Luke Porter
Not on the road :(
ib516 wrote: Check for the diagram on the backside of the panel cover. Open it up and flip it over. I'm pretty sure there's a diagram there with everything labelled.
Yes--I've looked at that--don't see windows.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
#40Fan
Colorado
Gas? Diesel? 1500? 2500? 3500? 5.9? 6.7?
2005 Keystone Outback Sydney 31RQS
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
#40Fan
Colorado
I went ahead and looked all wiring diagrams for all types offered and they are the same. There isn't a fuse. Power comes from the TIPM (own little computer that is part of the underhood fuse box).
Pull the driver's switch and check for power at the Pink with Yellow stripe wire, while the key is on.
Luke Porter
Not on the road :(
How do I pull the switch?
CampersX4
Oceanside, Ca
My vote is for the Master Switch being shot. My 04 has the same problem. All my fuses are good.
45Ricochet
North Idaho
Is it really cold outside? Only saying that cause mine will usually freeze up at least once per winter. Dog hates it when it happens
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Luke Porter
Not on the road :(
Anyone know how to get the switch out?
