RV.Net Open Roads Forum: Towing: Equalizer washers
Search only in Towing
Open Roads Forum  >  Towing
 > Equalizer washers
go wild
Minneapolis, MN
Posted: 02/26/12 08:14am Link  |  Print  |  Notify Moderator
I have an Equalizer WDH and need a few more spacer washers. Do I need to go to Progress Mfg to get these or would the local hardware store have them? Anyone have the exact specs on these washers?
Thanks!
2007 Jeep Commander 4X4 HEMI
2010 Jayco 17Z
ScottG
Bothell Wa.
Posted: 02/26/12 09:04am Link  |  Print  |  Notify Moderator
There's nothing fancy about them (hardening, etc). Just go to the HW store and get the same size.
Scott, Grace and Wesly
H0NDA eu2000i
Chuck&Gail
In the Colorado Mountains
Posted: 02/26/12 02:38pm Link  |  Print  |  Notify Moderator
On previous TT we had 6000# Equalizer. I needed another washer, so just added one from my junk drawer. After two trips (say 10,000 miles) it was squashed. I replaced with a hardened washer and had no more trouble.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
webslave
Clearville, PA
Posted: 02/26/12 09:33am Link  |  Print  |  Notify Moderator
As mentioned above, they are, BTW, hardened washers. I would recommend getting grade 8 washers; they are more than up to the task and won't flatten or deform under stress as a cheaper "hardware store" grade may. A regular washer can compress and that will allow the tension bolt (under the head) to loosen over time.
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
Claude B
Montreal, Canada
Posted: 02/26/12 11:46am Link  |  Print  |  Notify Moderator
Webslave,
Can you tell us how many tons of pressure will it take to ''compress'' a regular 1/2'' washer ?
Claude
2013 Gulf Stream VISA 19ERD
Nissan Pathfinder 2003
VW Passat 2012 TDI
goducks10
Keizer OR
Posted: 02/26/12 12:57pm Link  |  Print  |  Notify Moderator
There not enough preasure to smash a reg washer. I had to throw one in one time and didn't notice any diff. But at the same time if you need one and have the time to look while looking for one just try and find the hardened 1st.
webslave
Clearville, PA
Posted: 02/26/12 03:59pm Link  |  Print  |  Notify Moderator
Yep, happened to me, too. Voice of experience, I wasn't being smart. I "crushed" two standard "hardware store" variety washers. I found them crushed along about Nebraska when I started getting a "clunking" noise from the hitch. Took me awhile to figure out why the tensioning bolt on the bottom of my Equal-i-zer kept loosening up. It wasn't loosening, the two washers I'd put in had crushed and I found it when I noticed that they were sticking up much higer than the Equal-i-zer hardened washers. Even the Equal-i-zer manual specifies "hardened" washers. Grade 8's won't crush or deform.
* This post was edited 02/26/12 04:18pm by webslave *
goducks10
Keizer OR
Posted: 02/26/12 06:35pm Link  |  Print  |  Notify Moderator
10,000 miles is a bunch. Mine was only in for maybe a 1000. I guess there a reason they use hardened.
gmw photos
midwest
Posted: 02/26/12 07:43pm Link  |  Print  |  Notify Moderator
To be a little more specific, generally washers are either ( cheap ) carbon steel, case hardened carbon steel or through hardened. Washers are not usually graded as "grade 5" or "grade 8". What you want is a "through hardened" washer.
LarryJM
NoVa
Posted: 02/27/12 04:50am Link  |  Print  |  Notify Moderator
Incorrect CLICKY and you can even get them at your local HD/Lowes IIRC.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
 > Equalizer washers
