RV.Net Open Roads Forum: Tech Issues: Radio Display Blank
 > Radio Display Blank
TC&Z
Atlanta, GA USA
Posted: 02/26/12 08:53am Link  |  Print  |  Notify Moderator
We have a 2007 Winnebago MH, it came with a Magnadyne M9900CDS radio in the dash. The radio display worked fine until a few weeks ago. Now when the radio is off it no longer displays the time of day and there's no display light. Usually these are on when the radio is off. It behaves the same when the engine is running or when off. Yet the display works fine when the radio is turned on (and it has the correct time too).
Any suggestions how to trouble shoot would be appreciated.
Last resort I'll call Winn and Magnadyne.
Thanks
KJINTF
Montana
Posted: 02/26/12 09:08am Link  |  Print  |  Notify Moderator
Sorry,
The only suggestion I have is to toss it in the trash. Then check out the many great sites like Crutchfield and purchase a good unit. We bought our RV new in 2009 and replaced the Magnadyne within two weeks of taking delivery of the rig. I repair Radios TV Converters Inverters and the like, we tossed the Magnadyne in the trash.
Always more projects than time
bfast54
Traverse City ,Mi.
Posted: 02/26/12 09:15am Link  |  Print  |  Notify Moderator
It most likely has more than one power source...............check for a blown inline fuse, breaker somewhere.
Or ....it is a cheap unit, buy a quality replacement .
2000 Ford SuperDuty F-350 Powerstroke,Dually..The Tow Monster
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR temp,Garmin 1300 /GPS
Doran Pressure Pro
VU Qube Satelite
Rally's attended so far-16
My Blog
Good Sam Member
Beverley&Ken
Tottenham,Ontario
Posted: 02/26/12 10:49am Link  |  Print  |  Notify Moderator
Push the radio reset button on the front of the radio. Its between the preset5, band andEQ buttons, its recessed and you will need a small pointer to push it in. You will need to hold it in for at least 10 seconds to completely reset the radio (5 seconds did not work).
We have the same radio and the exact same problem. After a quick reset push didnot correct the problem, I checked every conceivable fuse, all OK. After pushing and holding for at least 10 maybe 15 seconds everything now works as before, even the funny characters in the display have disappeared.
Beverley and Ken
P.S. this radio was replaced under warranty (1yr) due to multiple problems.
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Matt_Colie
Southeast Michigan
Posted: 02/26/12 11:40am Link  |  Print  |  Notify Moderator
TC,
I don't know a Megnadyne from squat, but I can tell you that this is a feature that is selectable on most modern radios. If you don't still have the manual, see if you can download one. I wanted the Sony in my tracker to do what yours is doing, but it was perpetually on. I managed to change it.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
TC&Z
Atlanta, GA USA
Posted: 03/02/12 02:36pm Link  |  Print  |  Notify Moderator
Beverly & Ken were right !! I held reset for 15 sec and it now works perfectly. Glad it was this easy. A lot better than having to buy something. I need to fix and repair as much as I can right now vs replace with new.
Can't thank you enough, I appreciate your help...
