Blanco1
Los Angeles
I'm about to get my truck this week & now a friend of mine is shopping for a TC as well so I'll have a camping friend
Anyways while shopping he found that to back under a TC with a dually I will need this hinge?
Is this true?
The truck I took it off of was a SRW.
& looks like this.
1997 Dodge 4x4, 5 spd manual trans & HotRod 5.9 cummins.
With '85 Lance.
fast.5
Ontario, Canada
Hi: Yes you will have to get swing out brackets for the dually, the jacks will not clear the fenders.
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
tkcrawford
Edmonton, Alberta
fast.5 wrote: Hi: Yes you will have to get swing out brackets for the dually, the jacks will not clear the fenders.
Mike
What he said.....
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600
2008 Eagle Cap 995
Blanco1
Los Angeles
They cheap?
fast.5
Ontario, Canada
Hi: they will be around $200
Blanco1
Los Angeles
fast.5 wrote: Hi: they will be around $200
WHAT!!!!
FF1063
NY
Ah, same Blanco from the Cummins forum, have a nice day.
edited 02/26/12 01:55pm by FF1063 *
98' Ram 3500 DRW / 05' Arctic Fox 990
dakonthemountain
Crestline, California
Yup, sorry! NOT cheap. Keep a look out on Craigslist though...
Dak
1995 Weekender model 910 extended cabover
Calvin, the 1996 creampuff Chev Silverado 3500 extended cab dually
Escapee #22435
Blanco1
Los Angeles
Are they all Universal?
JoeChiOhki
Sauvie Island, OR
Blanco1 wrote: Are they all Universal?
The Rieco-Titan brand ones will fit them all, the Happijac brand won't work with your jacks and the Atwoods are spaced for atwood's bolt pattern.
I bought a set of Hijacker swing out brackets for a $100, then took them over to a friend of mine to beef them up a bit. I ended up still needing to add an additional piece of plate steel to get the amount of spacing I needed.
The big three brands will run between $199-250 for a set new, the Hijackers around $100-150.
http://www.towshop.com/store/pc/viewPrd.asp?idproduct=435
P.S. On the Hijackers the part welded to the center section is the end ya bolt to your camper .
I also center drilled mine and added an additional bolt hole on the side that bolts to the camper
CB Channel 17 Redneck Express
