RV.Net Open Roads Forum: Tow Vehicles: question about shocks
Search only in Tow Vehicles
 > question about shocks
campinginthewoods
Central ILL
Posted: 02/26/12 11:56am Link  |  Print  |  Notify Moderator
I have a 2004 F250 CC and I'm just curious how do you know if/when you need new shocks? I have 76k on the truck and mainly use it to tow my TT.Thanks for the help.
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/26/12 12:11pm Link  |  Print  |  Notify Moderator
Same basic test for any vehicle. If, after going over a bump, the vehicle continues to bounce up and down, the shocks are shot.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
skipnchar
Topeka or somewhere else
Posted: 02/26/12 04:05pm Link  |  Print  |  Notify Moderator
Besides the "bounce test" it would probably be a good idea to physically inspect them for signs of fluid leakage which is sometimes a precursor to a shock going bad.
Red,
Southwest
Posted: 02/26/12 12:54pm Link  |  Print  |  Notify Moderator
I wouldn't wait until my shocks are shot . . .
If your truck has ABS brakes on it ?
You need to have good shocks .
That's just a fact !
Red, *<(:{)-
Jarlaxle
New England
Posted: 02/26/12 04:26pm Link  |  Print  |  Notify Moderator
If they are OEM, you needed them about 76,000 miles ago. You will realize just how bad the OEM shocks are when you replace them with something better!
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
campinginthewoods
Central ILL
Posted: 02/26/12 12:23pm Link  |  Print  |  Notify Moderator
Ok thats what I was thinking but this is my first 3/4 ton truck so I wasn't sure...Atleast right now I don't need them. Thanks
campinginthewoods
Central ILL
Posted: 02/26/12 06:33pm Link  |  Print  |  Notify Moderator
Thanks Skip and Jarlaxle I bought the truck used so I assume they are OEM. It seems to ride fine still and Im just asking as it's my first 3/4 ton truck. I always try to do preventive maintence as I can I just relpaced my brake pads on the front and ended up replaceing all four rotors and pads. WOW that was hit to my wallet. But safety first also my mechanic says that I have a axle bearing going so thats my next project. Thanks for help I plan on keeping the truck for a long time so I'm taking care of things as needed.
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/26/12 09:04pm Link  |  Print  |  Notify Moderator
If you have an axle bearing going at only 76,000 miles, sounds like either that truck was worked very hard, or they ran it low on axle oil, or they ran it with contaminated oil.
