RV.Net Open Roads Forum: Oopsie.....well, back to the shop with the Jeep.
Open Roads Forum  >  Around the Campfire
 > Oopsie.....well, back to the shop with the Jeep.
NorthernLimits
Michigan
Posted: 02/26/12 01:45pm Link  |  Print  |  Notify Moderator
I think it's one ton axle time for Pammy.
Dutch_12078
Great Sacandaga Lake, NY
Posted: 02/26/12 02:11pm Link  |  Print  |  Notify Moderator
Sometimes you just need to have the right tool for the job...
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
mowermech
Billings, MT
Posted: 02/26/12 02:17pm Link  |  Print  |  Notify Moderator
Yes, of course!
Something like a Unimog, perhaps, but certainly NOT a Hummer!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Jarlaxle
New England
Posted: 02/26/12 02:30pm Link  |  Print  |  Notify Moderator
That looks less like an axleshaft problem than it does a broken ball joint.
What did you hit?
And is that a Rubicon?
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
Doug4.7
Hartselle, AL, USA
Posted: 02/26/12 03:12pm Link  |  Print  |  Notify Moderator
That or maybe a tie rod? Either way, it won't be fun getting it out of there.
travelnutz
West Michigan - On the Lakeshore
Posted: 02/26/12 03:57pm Link  |  Print  |  Notify Moderator
NorthernLimits,
Is the Jeep in the hills in the 532,000 acre Manistee National Forest in West/Northwest Michigan? We've seen several Jeeps with this same front end issue while riding the trails/backroads up there as we've owned acreage in that forest! since 1987 and 4 wheel/offroad motorbike/snowmobile there. Beautiful area and fun trails and hills! Never seen any other make of production vehicle with the same breakage issues, just Jeeps! As someone had posted, they must not be up to the task!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
Jarlaxle
New England
Posted: 02/26/12 04:04pm Link  |  Print  |  Notify Moderator
The camber angle on the tire makes me thing the ball joint went. A broken tie rod or tie rod end is actually pretty easy to field-fix and limp off the trail...a BJ, not so much!
Old-Biscuit
Across the USA
Posted: 02/26/12 05:38pm Link  |  Print  |  Notify Moderator
I like the windshield motto:
IT'LL BUFF OUT
Dutch_12078
Posted: 02/26/12 06:13pm Link  |  Print  |  Notify Moderator
mowermech wrote:
Yes, of course!
Note that it's a real Hummer, not one of those GMC imitations. Check the ground clearance...
Dutch
NorthernLimits
Michigan
Posted: 02/26/12 07:34pm Link  |  Print  |  Notify Moderator
Hummer is WAY to big to fit through the trails we run and wouldn't make it through the rocks we wheel in. The limited articulation of the hummer and sheer size makes it not correct for the wheeling we do.
Jeep in the pic is a standard Jeep Wrangler, not a Rubicon. Locked front and rear axles, alloy axle shafts, 4.0 with a manual and 35 inch Pro_Comp X-Terrains.
No it's not a ball joint. CV axle shaft, unit bearing, brakes and drag link were damaged. To get it off the trail....Pinched off brake line, installed spare unit bearing and axle shaft, wired drag link up. Towed out with another Jeep.
Wheelin was done near Grayling Michigan.
