RV.Net Open Roads Forum: Fifth-Wheels: Shore Line Extender
 > Shore Line Extender
RoyB
King George, VA
Posted: 02/27/12 07:53am Link  |  Print  |  Notify Moderator
I wouldnt change any of my RV Trailer wiring around just to save a couple of bucks... Be safe and just purchase the various adapter cables you need and keep in the RV TOOL BOX. I have my 50A-30A amp situations convered, my 30A-15A situations convered, and even an additional 30A (M-F) 25-foot extension cord situation covered. Never know when the situation comes up and we all know we RV'ers always got to have a PLAN-B or you face the wrath of the Titans. My wife is a full blown Texan and its very true they all shoot first then ask questions as it should be. Somehow I know this first hand haha...
When I pull into a BASS PRO SHOP parking lot for an overnight sleep over and they have 120VAC Receptacles in their RV Parking area I can just safely plug into it and run everything inside my trailer in the 15AMP power down mode..
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
snowshe
alberta
Posted: 02/27/12 08:16pm Link  |  Print  |  Notify Moderator
I'm afraid you are stuck with $80 solution be cause your Rv uses the Marinco shore power setup and these cost more the than the other type. For what it is worth, the 50 amp marinco plugin female to 30 amp male adapter would be my choice as you can now add a small 30A/15A adapter (3$) to run from the house power.
You'll also need a 50A Rv female (not marinco) to 30A male adapter so you can plug in to 30A shore power (you may have one already as they often come with the RV). I also carry a 50' 30A extension cord for when the shore power post is a bit of stretch for the normal 25' cord that comes with the RV.
Bob and Marlene
2008 COLORADO 28RK 5er
2006 GMC 2500HD Crew 4X4 SRW Duramax / Alison 6spd
Reese round tube slider with 15000lb 4way tilt
Podigy brake control
Don't Buy New -- Reuse and Recycle DRIVE a HOT ROD
1946 Chev Fleetline Resto mod
ritterjd
Vandalia, Ohio
Posted: 02/29/12 04:55pm Link  |  Print  |  Notify Moderator
I thought that a 'shoreline' extender was one of those things that you sent the rookie to the store to get. Same as the left handed monkey wrench.
John Ritter
Vandalia, Ohio
2012 Canyon Trail Aztec 33FRET
2006 Ford F350 DRW King Ranch 6.0L Powerstroke Diesel
hunts500
stockton, calif.
Posted: 02/28/12 03:55pm Link  |  Print  |  Notify Moderator
I ordered a short pigtail which goes from the trailer 50 amp to a standard 20 amp connector (its only about 12" long). I then use a standard extension cord connected to a 20amp circuit in the garage while getting ready to leave or when we come home, and it runs the fridge, tv, heater, and lights for the day or two on either end of a trip, without having to lug out the 50 amp cord. I ordered it from Dyers Rv on the web. Was unable to find it anywhere else, including Camping World.
rthibodaux
NewOrleans(Marrero), Louisiana
Posted: 02/27/12 08:25pm Link  |  Print  |  Notify Moderator
Just bought one at Amazon, 50 amp screw plug to household plug. $80.00.
cwit
Upstate New York
Posted: 02/28/12 07:03am Link  |  Print  |  Notify Moderator
Just plug in factory cord and then buy the cheaper adptors from wallmart. You can do it all for 30.00 dollars or less. This is what I do. I can carry my twist to lock 50 amp cord and save a ton of money. I think the twist to lock is a nice feature but the fittings are way to expensive.
Silveradomike
Rowland Heights, California
Posted: 03/01/12 09:27am Link  |  Print  |  Notify Moderator
I would save the $$ and just use propane for the Frig. It does not use the much propane to cool the Frig. I do this most of the time unless I need lights in it for a while.
2005 2500HD Duramax/Allison,Air-lift Bags,CST 4" Lift,Nitto 297/75/16
Reese 16k/4way Pivot,BlueOxe Bed Protector
2004 Northwood ArcticFox 27-5L,Honda 3000U Generator
