RV.Net Open Roads Forum: Does rear end gear ratio swap require programming?
Search only in Tow Vehicles
 > Does rear end gear ratio swap require programming?
WyoTraveler
Wyoming
Posted: 02/27/12 07:42am Link  |  Print  |  Notify Moderator
Interesting. I have a 2002 F250 6.8L V10 with a 3.73 differential, and a 2008 F250 6.8L V10 with a 4.10 differential. I get about 10% better gas mileage in my 2002 with the 3.73 differential. My 2008 F250 with the 4.10 differential definitely pulls my goose neck stock trailer better. Using a little math I also see there is a 10% difference between the 3.73 and the 4.10 differentials. I see the 10% difference in gas mileage but it would be difficult to say if there was a 10% better towing with the 4.10 differential. It is enough better that I can notice the difference towing when the stock trailer is loaded.
I have also been thinking of changing out the differential in my 2002 F250 to a 4.10 differential.
JIMNLIN
Oklahoma
Posted: 02/27/12 08:00am Link  |  Print  |  Notify Moderator
Your only gaining approx 250 rpm at 65 mph by going with the 4.10 gears with 31" tall tires.
Dropping to a 29" tall tire will give you about 2800 rpm at 65 mph.
Both numbers are in 1:1 drive or 3rd gear.
If your wanting to tow in OD gear then the 4.56 gear will work. However if your truck is a commuter you won't like the high rpms and reduced mpgs at crusing speeds.
APT
SE Michigan
Posted: 02/27/12 08:12am Link  |  Print  |  Notify Moderator
For 2WD, may be worth $500. Not worth $1500+ for a 4WD for both axles. IF you want to change, go to 4.56 if you want to feel significantly more power.
2012 VW Passat TDI
2017 Subaru Outback 3.6R
WyoTraveler
Wyoming
Posted: 02/27/12 08:19am Link  |  Print  |  Notify Moderator
I just checked it out with a mechanic. Requires both axles since it is 4WD. Not worth the cost.
gmcsmoke
Butler
Posted: 02/27/12 10:07am Link  |  Print  |  Notify Moderator
whisperide wrote:
gmcsmoke wrote:
For a 6.0L a 4.28 would be the best overall gearing. 4.56 would be a tow beast but kill you unloaded.
How did you arrive at this mythical 4.28:1 gear? What tire size were you figuring? And more gear doesn't always hurt average MPG, even if most of your miles are highway and non-hauling.
You're right not sure what I was thinking should have said 4.30.
Hannibal
Tampa Bay Area
Posted: 02/27/12 06:03pm Link  |  Print  |  Notify Moderator
Thanks for the heads up whisperide. I thought they all read off the ring gear anymore.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 96k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Equalizer 4 pt 10k.
NorthernLimits
Michigan
Posted: 02/27/12 06:11pm Link  |  Print  |  Notify Moderator
500 for one axle but 3 times as much for 2 axles? Remind me not to go to your shop.
time2roll
Posted: 02/27/12 06:39pm Link  |  Print  |  Notify Moderator
Sometimes the front is more complex. Although $500 does seem low.
+1, go 4.56 or don't bother. I would add Trutrac limited slip to the front while you are in there same to the rear or a locker. I went Trutrac on both.
Mine needed a programmer but that tells you nothing for your vehicle.
675w Solar pictures back up
Jarlaxle
New England
Posted: 02/27/12 07:01pm Link  |  Print  |  Notify Moderator
ARe 4.56 gears even AVAILABLE for the front?
John and Elizabeth (Liz), with 2 nutty cats...RIP, Maya ">
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
SoCalDesertRider
Arizona desert
Posted: 02/27/12 07:55pm Link  |  Print  |  Notify Moderator
They probably are. It's a GM 1500 4wd front axle. Plenty of lifted 1500 4wd pickups out there with monster tires on them. Has to be a few aftermarket gear manufacturers making 4.56's for that axle.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
