rfaivre
Bend, OR.
I am getting ready to replace the tires of my 31ft class C because of the cracks on the sidewalls. I was told by three different tire stores that I will need to replace all six tires. The tires on my rig as of now only have about nine thousand miles on them, with alot of tread left on them. My question is, would I need to replace the inner tires on the rear as well, since they have not been exposed to the elements as much as the outer tires?
Bowling Green, KY
Moved from ATC
crawford
Dandridge Tenn.
You should replace rear duels as a pair. because the diameter needs to be the same, so load is equal on both. If you change only one you will over load one tire and boom any questions?
ed6713
FL
Vehicles have two major safety systems; brakes and tires. That's no place to be cutting corners. Replace the tires.
Travel is fatal to prejudice,bigotry,and narrow-mindedness,and many of our people need it sorely on these accounts. Broad,wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime.
Handbasket
Asheville, NC
If they're Michelin LTX's and not too old, Michelin has been known to pick up some of the cost of replacing prematurely cracked tires. Don't know if they're still doing this or not, but it's worth asking at a Michelin dealer.
Jim, "In 1869 the waffle iron was inverted, thus ending forever the dreadful problem of wrinkled waffles."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Beverley&Ken
Tottenham,Ontario
When we replaced the Michelin LTXs on our C last summer, the inside duals were just as cracked as the outers. Not worth the risk of tearing out expensive RV components.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Rolin
Oregon
Hi rfaivre, After purchasing my lightly used motorhome I had the same problem. I know that safety is important, but 6 tires all at once was beyond my bank account at the time.
After looking at age and the the cracking, figured that front tires were the biggest safety concern so I purchased front tires first, put the best four of the original 6 tires on the rear and then replaced all four rear tires later.
Now my goal is to wear them all out, hate to have all that tread left over.
rfaivre
Bend, OR.
I thought I should replace all the tires, I just wanted to make sure that the tires dealers were not trying to make a extra buck. Thank you for you input.
jetenbu
Southeast Texas
NEVER NEVER NEVER skimp on your families safety by simply trying to save a few bucks, especially on tires. Enough said...... Life is too short already!
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
