RV.Net Open Roads Forum: Tech Issues: brake magnets
 > brake magnets
rvtroubles
AZ back yard
Posted: 02/26/12 07:28pm Link  |  Print  |  Notify Moderator
I had the drums resurfaced and new magnets installed last year.We took a 3000mi trip. When I checked the brakes this year both the magnets and the magnet contact surfaces on the drums were deeply grooved. My question is,WHY? This is on a 1999 Artic Fox,24ft 5th wheel.
Please,your help is appreciated. Thanks
skipnchar
Topeka or somewhere else
Posted: 02/26/12 07:53pm Link  |  Print  |  Notify Moderator
Can't tell you WHY but that's a painfully low mileage to be showing any visible signs of wear. Could it be that they only resurfaced the braking surface not the side of the drums?
chinook507
Fountain
Posted: 02/26/12 08:48pm Link  |  Print  |  Notify Moderator
Did you by chance have grease leak out and get all over the insides of the drums?
2001 Excursion V10
2010 Dunesport Monsoon
1997 Kawasaki 1100STX Jet Ski
1991 Kawasaki Bayou 300 4X4
1989 Kawasaki Bayou 220 2X4
mike4947
N. Syracuse, NY
Posted: 02/26/12 09:59pm Link  |  Print  |  Notify Moderator
We've seen this a couple of times. Mostly it's caused by a stray voltage being applied to the brake wires. Most common cause is a short in the 7 pin connector. Either from dirt or a bad wire. Usually it's a low voltageshort and causes wear on the magnets/surfaces, but not the actual linings or main drum surface. Espwcially if the brakes haven't been adjusted.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
Likes to tow
Huntington WV
Posted: 02/27/12 03:31am Link  |  Print  |  Notify Moderator
Are you sure the magnet surface of the drum was turned?? Not all shops have the ability to turn this vertical surface and can only turn the outside surface where the shoes contact. If you had this work done and did not do it yourself I would question the validity of this surface being done!!
jasult
Central NJ
Posted: 02/27/12 03:44am Link  |  Print  |  Notify Moderator
Hi Guy - Can't be sure but if you have no problem pulling it apart to check it why did you not just replace the entire backing plate as a kit and install new drums for same cost you paid a shop to do the work? You did the hardest part of jacking up and pulling apart.
These backing plate kits come with everything new and shoes and springs installed. Just unbolt old and install new and drums and done.
Here are some to check out and most local trailer shops carry them
Trailer brake kits
* This post was edited 02/27/12 03:50am by jasult *
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
jasult
Central NJ
Double post
Chris Bryant
DeLand, Florida, USA
Posted: 02/27/12 05:02am Link  |  Print  |  Notify Moderator
That would be my bet as well.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Wills250psd
walnutcove NC
Posted: 02/27/12 05:07am Link  |  Print  |  Notify Moderator
eastern marine has the parts cheap
mapguy
Puget Sound
Posted: 02/27/12 09:38am Link  |  Print  |  Notify Moderator
Deep scores may be real minor issue in the overal scheme of things. Deep scores are only a problem if damaging the magnet core and or the wear pattern is not proper. Magnet condition and drum magnet surface must be in harmony. New magnet needs fresh magnet drum surface. Old magnet needs the drum surface to stay the same to match the existing magnet.
Not sure which brand of brake is on your trailer but the Al-Ko Axle manual is at the link below. See page 17 for magnet info. Similar information for Dexter Brakes is available on the Dexter Axle website.
2-7K Al-ko Owners Manual
 > brake magnets
