Gulfstream 8378
Pleasant View
I am new to the RV world and had a house battery blow up today. If the converter is putting out to much power can it be adjusted? I had it hooked to shore power. It is on a Gulfstream 8379 coach. What would cause this to happen? Any ideas before I get ripped at a dealership.
Oasisbob
Portland Oregon 97266
My initial guess would the terminals were reversed. That is to say ground went to positive and Positive to ground. You can check converter to battery output with a simple volt meter. Should not be more than 14 volts D.C.. There are certainly more knowledgable folks here than I am. Can you give us more info? Was the battery newly installed? Hope no one was hurt.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
CA Traveler
The Western States
It could have just been a defective battery. Buy a $10 digital voltmeter and post the charging voltage with the next battery.
Post the converter type and model.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Mustang7370
Washington State
So did it blow up, like KABOOM! Or did it swell up and leak all over? When you are connected to shore power, most units will overcharge the battery if left plugged in for days or weeks on end with no loads. It is important that the battery water level is checked on a regular basis. As the battery charges up, hydrogen gas is created and is very explosive. Disconnect from shore power if you plan on storing or parking the RV for long durations of non-use. Disconnecting the battery and storing it in a dry location is not a bad idea either. When connected to shore power, check the voltage on the battery with a meter. It should run around 13.0-13.5 volts. If it is pushing 15 volts, you have a converter issue which needs to be addressed.
Chris and Kelli Withers
Ferndale, WA.
skipnchar
Topeka or somewhere else
blowing up a battery is usually a sign of an internal short which causes overheating until the hydrogen gasses blow. Usually preceded by a smell of sulphur from the battery compartment.
jwmII
out west
I have to go along with the shorted diagnosis. Probably 1 cell shorted and that is enough to blow the battery when the charge is steadily put to it. The H2 builds up and it goes. Very dangerous.
jwmII
bdpreece
Woodburn Oregon
One cell shorted causes a low over all voltage which tells the charging system to charge the battery at a high rate. This causes the battery to overheat and boil or in some instances even explode. I smelled what I originally thought was sewer gas in my coach but when I opened the battery compartment steam was pouring out of on of my house batteries. I was lucky I got it disconnected before it blew.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2008 Ford Explorer toad
fcooper
Richmond Hill, Georgia
I agree that most likely a shorted cell. I had one blow up on a houseboat connected to a 3 stage charger. Replaced the battery and all was well. Just the luck of the draw. Not a bad idea to check the charger but I'd bet it is fine.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
rv2go
Fulltime (Knoxville, TN).... or someplace else
I had a 6 year old chassis battery blow up while parked at my site. Sounded like a shotgun blast. Blew one side completely off. I hosed down the area with lots of water. Replace both batteries and all was well.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Alan_Hepburn
San Jose, Ca, USA
Yup - I had a battery explode in my Jeep many years ago, in the garage. Got in to go to work one morning and as soon as I turned the key to start the engine I had an explosion under the hood. Two cells were shorted and when I drew the starting current from the battery it was enough to cause an internal spark and "BAM"!
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
