RV.Net Open Roads Forum: To Plug In or Not To Plug, That Is The Question
 > To Plug In or Not To Plug, That Is The Question
JIMNLIN
out here
Posted: 02/27/12 07:28am Link  |  Print  |  Notify Moderator
I always unplug my '97 5er as the units appliances have just so many hours/duty cycles their designed to last or operate. However my unit sits in its shed out by the tractor barn so its easy for me to see to its needs 24/7.
If you notice many folks that say they leave them running have fairly new units. When you have a converter/LP fridge and other appliances go down while it sits plugged in (not camping) you have a different perspective of leaving it plugged in all the time.
'97 Park Avanue 28' 5er 11200 gvwr two slides
DSteiner51
Wooster, Oh
Posted: 02/27/12 07:53am Link  |  Print  |  Notify Moderator
Over ten years on mine and I leave it pluged in. I leave the frig on full time with food in it. When not camping it is my office and when i decide to go camping it takes me approx 10 minutes to load medical stuff and another 10 minutes to hook up and be on the road.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
bukhrn
Lanexa, Va
Posted: 02/27/12 06:35pm Link  |  Print  |  Notify Moderator
Mine stays plugged in 24/7 at home, I do check the batteries every month.
2007 Forester 2941DS
2005 KIA Spectra
Wherever I happen to park
Posted: 02/27/12 07:54am Link  |  Print  |  Notify Moderator
The answer to your question is determined by the answer to a question:
What make and model converter do you have?
MOST, modern RVs epically the high end uints, have 3-stage "Smart" converter/chargers. and can be left plugged in full time.
Some, older or low end rigs still have single stage battery killers. and should nto be so left.
christopherglenn
a little over an hour from Yosemite
Posted: 02/27/12 12:17pm Link  |  Print  |  Notify Moderator
Mine is on a timer, I give it power a few hours a night to keep the batteries charged. Cuts down on the electric bill at home, and if I need to be in it, moving the plug from the timer to the 50 amp socket takes 10 seconds.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
mlts22
Austin, Texas
Posted: 02/27/12 01:28pm Link  |  Print  |  Notify Moderator
If you have a single stage converter, and are not running much inside the RV, you might consider a Battery MINDer, either a 1A or 8A version. This will keep the jars topped off, and use very little power. If you have a multi-stage converter, probably your best bet would just to be to use that.
RVBlade
Tampa Bay Region, FL
Posted: 02/29/12 05:19am Link  |  Print  |  Notify Moderator
Thanks everyone for the great replies! I've monitored this thread over the last couple of days, but this is the first chance I've gotten to reply. I appreciate everybody's input.
I would imagine my new rig will have one of the 3 stage chargers some of you have talked about given the price and feature level of it. But, it will definitely be something I ask about at the PDI walk-thru.
Working off of that assumption, I'll probably leave it plugged in at least while it's inside the garage/condo and I don't have to worry as much about theft of the cord. At the point that we have to move it outside to the 15A service, I'll re-evaluate from there.
Thanks again.
2005 Ford F350 CC Lariat DRW
2012 Sanibel 3400
DW & DS (10)
Ceaser (our 140 lb Bull Mastiff) & Sake' (our 135 lb Akita)
FunnyCamper
Southeastern
Posted: 02/29/12 05:24am Link  |  Print  |  Notify Moderator
ReneeG wrote:
Mandalay Parr wrote:
Leave it plugged in.
Agree. We keep ours plugged in between trips here at the house (turn on the fridge a few days before each trip).
This is me. I agree.
Jerry9n
SE Michigan
Posted: 02/27/12 10:48pm Link  |  Print  |  Notify Moderator
Rather than keep my converter powered up, I have a disconnect switch and a trickle charger that runs 24/7. I put a connector for it in the side of my storage box on the tongue and run a light extension cord to a standard outlet on my pole barn. This also saves exposure of my 30A cord to the sun and weather all winter.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
Us out West
Let's see...last night we stayed in......
Posted: 02/27/12 06:44pm Link  |  Print  |  Notify Moderator
on our previous TT I installed solar on the roof to keep the 2 6volts charged between trips and over the winter. Worked great for storage and when we went to places with no hookups.
We had to move our storage with the new Pinnacle to a club members home where he has plenty of room in the back for us and another member. He has electric plug in available and will now take advantage of that little perk.
Our Trip Journal
2012 Jayco Pinnacle (View)
36KitchenPantryTripleSlide
MorRyde pin box and suspension
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
2009 Silverado 3500HD 4X4 (View)
CC,
Dura-Max 6.6/Allison
LB
DRW
American Tank 65 gal. Aux Fuel
