RV.Net Open Roads Forum: Ford V10 - pros and cons of the 2003 versus the 2012.
 > Ford V10 - pros and cons of the 2003 versus the 2012.
mozim
Evergreen co
Posted: 02/27/12 10:32am Link  |  Print  |  Notify Moderator
What are the pros and cons of a 2003 Ford V10 versus the new V10? We are looking at purchasing a 2003 Pleasure-way with a V10 engine.
* This post was edited 02/27/12 09:19pm by mozim *
n7bsn
Yes
Posted: 02/27/12 10:36am Link  |  Print  |  Notify Moderator
As I recall, there is no difference between the 2003 and the 2012 V10 put in the E series chassis. Both are the improved crank, 2-valve engines. By 2003 the issue with the spark-plugs had been cured
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
skipnchar
Topeka or somewhere else
Posted: 02/27/12 10:44am Link  |  Print  |  Notify Moderator
Not sure about the application but most 2005 and newer were three valve engines with a HUGE horsepower jump. MAY be just a truck thing, I'm not sure.
n7bsn
Yes
Posted: 02/27/12 11:54am Link  |  Print  |  Notify Moderator
The three-valve were never factory installed in the E series chassis
NewsW
US
Posted: 02/27/12 01:32pm Link  |  Print  |  Notify Moderator
Even in the E-350, the 5.4 is a 2 valve engine.
Now, someone can always retrofit... but quite frankly, it is a more reliable engine.
skipnchar
Posted: 02/27/12 02:57pm Link  |  Print  |  Notify Moderator
Thanks for the update. I suspected as much.
Gale Hawkins
Murray, KY
Posted: 02/27/12 06:59pm Link  |  Print  |  Notify Moderator
Price and Price.
mumkin
Minot ND USA
Posted: 02/27/12 07:39pm Link  |  Print  |  Notify Moderator
I don't think that there are many B's with the V-10. They are usually on the E-350 with the 5.4.
Perhaps you are thinking of C's and this question should be on that board since there would be more experience.
Mumkin
2011 LTV Libero
Tech Dude
Torrance
Posted: 02/27/12 11:07pm Link  |  Print  |  Notify Moderator
Al vans have 2 valve
Johnny Buoy
Maritimes, Canada
Posted: 03/01/12 10:43am Link  |  Print  |  Notify Moderator
One of the options at PleasureWay is the 6.8L V10. The used 2005 Excel we bought had this option and I like the 5 speed transmission it comes with. No regrets! Fuel consumption is a little higher but I like the extra power and all features of the TorqShift transmission.
I tried to change the plugs myself but quickly brought it to a truck shop for that – too risky for me.
Just be careful that the 2003 model you are looking at is running on a 2003 Ford chassis, not a 2002 – it is possible.
Good luck
