RV.Net Open Roads Forum: How many stages on a PP 7155 converter?
 > How many stages on a PP 7155 converter?
mlts22
Austin, Texas
Posted: 02/27/12 10:51am Link  |  Print  |  Notify Moderator
I couldn't find this anywhere on their website:
How many stages does the Parallax Power 7155 converter have? I found nothing on their website.
ScottG
Bothell Wa.
Posted: 02/27/12 11:00am Link  |  Print  |  Notify Moderator
According to the specs it's a single mode output. For the same price or less, you can get a 3 stage from Best Converters.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
BFL13
Victoria, BC
Posted: 02/27/12 11:11am Link  |  Print  |  Notify Moderator
Single stage at 13.8v. But some have an option called T which gives them some time (13 hours ISTR) on start-up at at a voltage in the low 14s. Look on the label plate Options section to see if yours has a T. (not likely)
The 13 hours was considered too long at the higher voltage so the new Paramode version which has two stages only stays in boost for 4 hours after start-up, then drops to 13.6v.
I kept the 7355 as the converter for when on shore power, and use a portable 40amp smart charger for fast charging with the generator when camping.
Others have swapped out their single stage converters for fancier converters, but must also do a lot of work to replace the original converter to battery wiring with fatter wire, so the new converter will do any better than their old converter did.
To avoid the re-wiring, you can leave the 7155 in place and mount a new converter up close to the batteries with short fat wire to get good amps with the gen, and you can use either converter as your shore power one.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
mlts22
Austin, Texas
Posted: 02/27/12 11:20am Link  |  Print  |  Notify Moderator
Thanks. I'm thinking I am going to go with a portable 40A charger. Any brand recommendations?
Also, would there be issues running the charger while I have the converter in use as well? The generator I have can easily handle the wattage from both at the same time (40A + 55A, so about 1140 watts.)
This partially explains why my OEM jar got boiled away in four months. That, plus the fact that I deep-discharged it one too many times.
BFL13
Victoria, BC
Posted: 02/27/12 11:32am Link  |  Print  |  Notify Moderator
This is a really good one, maybe the best:
http://boatandrvaccessories.com/VEC-1093DBD.htm
You can plug the rig into the gen and plug the charger into the gen and clamp on and run both at the same time. ( If the charger won't run, start it first and then plug in the rig and so the 7155. Might happen or not -doesn't matter it is not an "issue")
They will not add their amps much, so in effect all the work will be done by the charger at its higher voltage (14.8 vs 13.8). Once the batteries reach 13.8v no amps can flow from the 7155, and it will reach 13.8 very quickly.
Since the batteries only charge at net amps, if you have 5 amps of 12v things running in the rig while charging you will be charging at 35 amps and take longer gen time. So if that is a problem, you can disconnect the batteries and let the 7155 run the rig 12v (the 7155 does not need a battery to be connected) while the charger does the whole 40amps into the batteries.
Wherever I happen to park
Posted: 02/28/12 09:03am Link  |  Print  |  Notify Moderator
Single stage
Home is where I park it.
