RV.Net Open Roads Forum: Anyone ever made they're own Fuel Tank ??
Search only in Toy Haulers
 > Anyone ever made they're own Fuel Tank ??
Bumpyroad
Virginia
Posted: 02/29/12 03:21am Link  |  Print  |  Notify Moderator
Francesca Knowles wrote:
Sometimes the right answer isn't the one you're looking for, O.P.!
You ask if anyone's ever built their own gas tank.
Pretty much, everybody's checking in saying
"Why would I do that, when there are so many other existing practical alternatives"?
But, hey!
If you'd rather do it yourself, you just go right ahead and do it!
Just don't expect anybody to tell you it's the smartest/most practical/cheapest/safest alternative to your extra fuel-carrying problem...
Bingo, we have a winner. I think that is all people have tried to say with "constructive" criticism or alternative suggestions. IMHO there is way too much knee jerk "approval" of various questions raised in this forum.
bumpy
Bumpyroad
Virginia
Posted: 02/29/12 05:25am Link  |  Print  |  Notify Moderator
Dirtclods wrote:
Bumpyroad wrote:
since we are straying off topic, if you make your own gas tank, ever have a wreck where it bursts and a fire ensues, get out your check book.
bumpy
Man speaking of off topic!! Did you see that explosion at Daytona 500 I wonder if that was a legal container he had fuel in?
Sorry you haven't found the answer you're looking for...yet.
Not claiming to be an expert on NASCAR requirements, since I feel NASCAR racing is really designed to appeal to folks who can't grasp the subtle nuances of professional wrestling, I would "guess" that gas tank specifications for cars and other equipment is highly regulated.
bumpy
mrxlh
Bossier City, LA
Posted: 02/29/12 06:23pm Link  |  Print  |  Notify Moderator
You can build one in a heart beat. Figure out where you want all the connections, add baffles, I would recommend testing it to 6psi and use a 4psi releving cap in case the vent ever stops up. Soap and water works great on for finding the leak if it has one, alot cheaper than dye check and alot cleaner.
The davantages to building your own are you can make better use of the space you have. (get a larger tank than a straight up 20 or 30 gal) Just keep in mind what needs to support the tanks weight. The empty weight of the tank, the weight of the fuel capacity, and I would add a 30% weight margin in for slosh if its not completely full.
So if your total is 400 lbs, add 30% to it (520 lbs) and that is what the supporting structure needs to be able to handle.
Ryan
2008 Ford F350 CC LWB Dually
2011 Raptor 4014LEV
2006 H-D FLHX
2010 Honda Rancher 420ES
dodgboy
Northern CA
Posted: 02/29/12 09:35pm Link  |  Print  |  Notify Moderator
I made one for my old one lunger Fairbanks engine, it was about 2 gallons. I had a metal supplier cut and bend 2 sheets of lightweight metal then I simply welded them together and added flat stock across the bottom to attatch it. I used the correct size pipe fittings for the fuel line and filler.
2005 Dodge 2500 4X4 Cummins, BD Exhaust Brake, Edge Juice W/ Attitude, Banks Technicooler.
2009 Enduramax G-Force 3105 Toy Hauler
2012 Polaris RZR XP 4 900
2006 Kawasaki KFX400
2112
Posted: 02/29/12 10:24pm Link  |  Print  |  Notify Moderator
I modified my motorcycle tank to enlarge it from a 3.2 gal to a 5.4 gal. I didn't know I needed to be certified. Take your time, use common sense, test it and clean and coat the inside with KBS.
2011 Ford F-150 EcoBoost SuperCab, Timbrens, PullRite SuperGlide 2700 15K
2013 KZ Durango 1500 2857
nickelAF
Charleston, WV
Posted: 02/29/12 11:03pm Link  |  Print  |  Notify Moderator
Did I miss something at the Daytona race I was unaware any explosion happened. I did see a fuel oil fire, no explosion.
If you are a proficientnt welder have some metal cut and bent to your needs. Making your own custom tank that fits your application has its advantages. PRESSURE TEST TO 6 lb. I would however, first shop for something off the shelf that suits your needs, probably cheaper and less of a pain.
07 Arctic Fox 31WRB
04 6.0L 4X4 Excursion
Dirtclods
Newport Beach
Posted: 03/01/12 08:16am Link  |  Print  |  Notify Moderator
Man stay on topic! Fire photo: http://sports.espn.go.com/espn/gallery/enlargePhoto?id=7623110&story=7622987
http://news.yahoo.com/fiery-explosion-hi........ts-wild-crazy-daytona-500-101536569.html
I sure there's something on U-tube.
Oh-(Sorry you haven't found the answer you're looking for...yet too! )
Mongo68
CA
Posted: 03/02/12 11:54pm Link  |  Print  |  Notify Moderator
I saw some last time I was at Walts, but I think I could make one that fits the space better. Only catch is I cant weld well enough. Whatever you choose- premade or DIY, take pics so we can copy.
Good luck and dont explode! Think how off topic that will get...
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6 Tiki Edition
