RV.Net Open Roads Forum: Toy Haulers: New epic upgraded mattress
Search only in Toy Haulers
 > New epic upgraded mattress
asuperheat
Posted: 02/27/12 05:51pm Link  |  Print  |  Notify Moderator
To those new epic owners how is the upgraded/heated mattress in the epic? Does it sleep ok? Mine will be here soon and was wondering if it will be a problem.
randot
Ellensburg, WA
Posted: 02/27/12 08:57pm Link  |  Print  |  Notify Moderator
We slept on it the first night and were surprised how much we liked it. We asked the dealer about the "heat" function and no-one could tell us anything about it which was the case on most things – we seemed to know more about the TH than the salesman did. Anyway, we decided to keep the plastic on the mattress until it was definite we wanted to keep it. We took the plastic off last week and guess what.... we found the controls to the heater (separate for each side). Have not tried it yet, but glad we finally solved that mystery.
2012 Ford F350 Super Duty
2013 Voltage 3200 EPIC II
Two GSDs and toys
Crazy Cooter
West Coast
Posted: 02/27/12 09:27pm Link  |  Print  |  Notify Moderator
12V or 120V?
Been thinking of a heated mattress pad to warm up before tucking in on those cold nights.....
1999 Peterbilt 385
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2010 NuWa Hitchhiker 36LKRSB
2012 Cyclone 300C Triple Axle
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
randot
Ellensburg, WA
Posted: 02/27/12 09:56pm Link  |  Print  |  Notify Moderator
Crazy Cooter wrote:
12V or 120V?
120v - one controller with separate adjustments for each side
DodgeVoltage
MD
Posted: 02/27/12 11:59pm Link  |  Print  |  Notify Moderator
Mine has a controller for each side (king size). I use it all the time- it's awesome! Heat stays on for 8 hours and automatically turns off (if you don't turn it off sooner). I even have a 4 inch memory foam topper on top of the mattress from Bed Bath and Beyond.
As far as the mattress, never used it without the add on topper. Wife did once for a nap in the driveway and said it killed her back- hence the topper.
2010 Dodge 3500 Mega Cab Cummins Diesel DRW
2009 GMC 2500HD D/A Crew Cab
2012 Dutchmen 3795 Voltage Epic Package
2012 Smart Fortwo Passion
2017 Smart Fortwo Proxy
AD USAF 1996-2011 1700+ hrs E-3B/C AWACS
NYANG 2011-Present
K-State Wildcats!
asuperheat
Posted: 02/28/12 05:54pm Link  |  Print  |  Notify Moderator
Thanks for the heads up on the controls. I also find the epic is new and most dont know alot about it. I wont be picking it up now for a few more days due to a slide issue that needs to be fixed found on walk through. I was hoping the mattress would be ok and I would not need to replace it for a while. Thanks for the replys.
jack0351
Santee, CA
Posted: 04/18/12 03:55pm Link  |  Print  |  Notify Moderator
My wife LOVES the heat function, but neither one of use likes how stiff the mattress is. I've slept on floors that felt more comfortable.
DodgeVoltage, you can use the heat function and feel it through the topper? If that's the case our mattress may stick around longer than I thought, I was going to swap it for the tempurpedic that was in the apt.
2013 Ram 3500 CCLB DRW 6.7 w/Aisin
2012 Dutchmen Voltage V3600 Toyhauler
2000 Harley FXST
randot
Ellensburg, WA
Posted: 04/18/12 11:15pm Link  |  Print  |  Notify Moderator
I had it wrong; it is two controllers etc as DodgeVoltage states here. It is really nice on a cold night and you can keep the propane heater on low.
A soft mattress makes my back hurt so it is on the firm side.
DodgeVoltage
MD
Posted: 04/19/12 08:36am Link  |  Print  |  Notify Moderator
Sure can. Turn it on 30 minutes ahead of time and it is nice and warm.
Dave Wilburn
Ogden UT
Posted: 04/19/12 02:55pm Link  |  Print  |  Notify Moderator
We spent two weeks in ours on the maiden voyage. It was pretty stiff, but with use it seems to be softening up a bit.
If you have young'ens, have them jump up and down on the bed to help break it in [emoticon]
04.5 Ram 3500, '12 Voltage 3905 Epic, 69 baja bug
