RV.Net Open Roads Forum: How to convert to LED lighting
 > How to convert to LED lighting
Page of 20
Grillmeister
BBQ TOUR USA
Posted: 03/20/12 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
1rosario wrote:
My Bathroom Vanity Has these:
What are your ideas for these "deco" bulbs?
TIA!
I am waiting for some ideas on this one too.
Show me the GRILL and STAND BACK!!!!
rgolding
Southern Illinois
Posted: 03/20/12 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
To the OP, thanks for this link. Taking the plunge with 4 of them because of your link and post. Thanks for showing this. I'll let you know my results.
troyb
Alberta, Canada
Posted: 03/21/12 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Well I received my order of the Chinese manufactured LED units 2 days ago and have started the transiton. Installed all of the "bulbs" and am now working on converting the floresent fixtures using the 36 panels. Put 6 panels into the floresent bathroom fixture and there should be no excuse of missing the loo! Unless you look at the light first! They are real bright and maybe too beight for the bathroom., but they work great. Discovered that I hadn't ordered a LED for one of my smaller bulbs (only one in trailer - inside step light) so I broke the glass on the bulb and soldered a LED push-in bulb into the base... and it worked! Someone noted earlier that they thought these led units may be polarity sensitive, and the are! So be aware, if they don't work when you first install them, you may have to "turn them around" so to reverse the polarity (the push-in bulbs anyways). So far all is much better than expected, and you can't beat the price.
2008 Chev 1 Ton Dually Crewcab Duramax, Banks Speedbrake and IQ
2008 KZ Escalade 37REB
troyb
Alberta, Canada
Posted: 03/21/12 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Incidently, thank you to Netboy for the info and getting the thought process going. Also a note about operating these lights on a dimmer... they work! Thanks again. Troy
Don & Linda
Western PA / Cape Cod
Posted: 03/21/12 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
TIA!
A home built rectangular oak box with a translucant lens and 3 or 4 24/50-50 panels would do nicely, I think.
If too bright, some say they're dimmable
NetBoy: We too, thank you for this thread. As with others, your thread with all it's informative posts, started my winter dulled brain into a higher gear.
I've ordered a small qty. of 48-3528's / 4x5(20) 5050's / 3x8(24)5050's to test brightness levels and try them in differing locations thru-out the trailer.
* This post was edited 03/21/12 09:40pm by Don & Linda *
1rosario
Phoenix, Arizona
Posted: 03/21/12 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
I found some on Amazon. Expensive, but I only need 3.
Or just replace the whole thing with a newer vanity that can replace bulbs.
Sorry, I couldn't make my links work.
Grillmeister
BBQ TOUR USA
Posted: 03/22/12 11:06am Link  |  Quote  |  Print  |  Notify Moderator
How about just copy and paste the links here?
Was it this one
NetBoy
Portland, OR
Posted: 03/23/12 02:04am Link  |  Quote  |  Print  |  Notify Moderator
TIA!
Pretty hard to give advice without knowing what base your bulbs have.
NETBOYâ„¢
Visit Netboy's Camper Project's Page = Lots of mod projects to my truck and camper.
My newest rig -- 2004 Thor Chateau 21RB:
1rosario
Phoenix, Arizona
Posted: 03/23/12 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Grillmeister wrote:
Was it this one
Yeah, those are it.
1rosario
Phoenix, Arizona
Posted: 03/23/12 08:21am Link  |  Quote  |  Print  |  Notify Moderator
and these are the lights I was thinking replacing with. Cheaper than those bulbs, I'm already getting some extra led lights for it, and updates my RV.
(BTW, Thank you Grillmeister! Now I know how to post my links. I tried the plain links before, but I got some smiley faces in the middle of the links )
Page of 20
