RollingRockTX
Keller, Texas
I also posted this on the crossroad site but figured I would get a quick response.
Hey folks
Need a little help. Our basement door has three latches. 2 thumb latches on the outside and a 751 lock in the middle.
Well for some reason, the middle one does catch, it's like the front got torked or twisted...so my work around was to install two locks on the outside and just leave the center as non working.
If they made an offset cam about 1/4 longer it would catch the back of the lip on the door.
Does anyone have any idea where I can find a longer cam to make this work?
Thanks
2006 Ford F250 King Ranch PSD
ARP Headstuds
ERG Delete
Diesel Site Coolant Filter System
Gearhead Performance Tuned, via XCALII, Edge Insight CTS
MBRP 4" Turbo Back, cat delete
MagHytech Rear Dif Cover
2011 Ford Expedition, HD Tow
2011 Cruiser CF33LF, KC5PFG
camperpaul
Wherever I park my travel trailer
I had to bend the "cams" a little on some of mine and they now work just fine.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
RollingRockTX
Keller, Texas
camperpaul wrote: I had to bend the "cams" a little on some of mine and they now work just fine.
The bend isn't the issue, the cam itself needs to be longer to make contact with the back of the lip on the inside.
Randu
South Central Michigan
The cam locks come in different lengths. Sounds like someone may have swapped out with the wrong length. Quick Bing Search came up with all kinds but 5/8 and 7/8 lengths are common. Randu
2004 GMC 2500HD 8.1 Big Block gas
2008 Mobile Suites 36TK3
RollingRockTX
Keller, Texas
thank you,
There are different depths for the lock assembly and different cam lengths. What I need is just the cam.
now I am obsessed with this darn thing
Swanny59
Lemoore, CA
Thanks
Your local locksmith should have different length cams at a reasonable price.
Ray & Addie
Lemoore, CA
2003 Dodge Ram 3500
2011 Sundance 3300QS
gotsmart
Aberdeen, WA
RollingRockTX wrote: thank you,
CW has 751 locks on the peg hooks. You may find it less expensive and less time consuming by just replacing the lock.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
Davehrn
Ohio
Some times the lip gets bent in..... I had to bend the inside lip of the frame closer to the door .. mine got bent into the storage bin... I hit it with something... its very pliable
~dave
2010 Coachmen Mirada 32ds
DW: Nora
DD: Silas White German Shepherd / Husky Mix
ford truck guy
Pennsylvania
Davehrn wrote: Some times the lip gets bent in..... I had to bend the inside lip of the frame closer to the door .. mine got bent into the storage bin... I hit it with something... its very pliable
X2... Was there a time when it all worked fine ?? Or has it not worked from day #1... I keep my chairs underneith,,, sometimes I need to BEND the lip around the opening to allow the lock cam to function properly... Joe
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
RollingRockTX
Keller, Texas
Something bent, like the entire door...the cam isn't long enough to even grab the back of the lip.
Just need a 1/4 longer cam and it will be good to go.
